Old 11-17-2012, 04:49 PM
Mine looked like that too. Dave re-did my head with stainless valves.(Upgrade from Ti) Stayed in spec all season. I hit the shaft with wet 800grit. When you replace the seal, push it in or leave it out a bit from its current position. The seal is about $4. The shaft is part of the cam at $150. What are you doing about piston/rings/cylinder?
Old 11-17-2012, 05:15 PM
I believe I have the parts for the factory clutch. My bike came with a box of the old parts that came with the bike. We can work something out.
Old 11-19-2012, 11:45 AM
Also if anybody is interested in my auto clutch and lhrb in trade for a stock setup let me know.
Curious on why the switch back...
Rising Sun Bio
Old 11-19-2012, 12:23 PM
rover67 rover67 is online now
I miss how I can control the front of the bike with a clutch. I like popping to get the front up and over stuff or to make the back hop. I also like wheelies which are hard with the auto clutch (it just spins the back tire).
If my clutch had the manual override I'd probably like it a lot more. Maybe i'll miss the auto clutch... not sure, I'm just ready to try something new.
Old 11-19-2012, 12:27 PM
I think I am gonna leave the piston and cylinder alone, maybe just re-ring it. I am also going to have Dave do the head. I'll look and see if I can find a fresh spot on the cam shaft for the seals to ride, I hadn't thought about just moving them to a different spot. That's a good idea.
I'll drop you a line on the clutch stuff!
