Old 11-19-2012, 01:03 PM
Default Squealing bearing - 80 series
The 's 80 has something squealing in the engine bay...I'm suspecting it is a pulley or pump...
Any common culprits I should check, and should it be parked until fixed?
I'd post up the sound file I recorded but I doubt that would help much...I don't think it is the belts (they are maybe 3 months old) and it isn't the slipping belt sound. Other than the noise, no other issues or problems but I don't want whatever it is to seize and cause other problems...
Old 11-19-2012, 02:22 PM
Use a sqirt gun or spray bottle and try squirting a fine stream of water at various rotating/moving things in the front of the engine while its running. If you can get the sound to change, you found the problem.
Old 11-19-2012, 02:47 PM
coax's Avatar
coax coax is offline
Extra tension-er pulley on the 2 main belts? I recall some folks have had that go out.
-Corey
'74 project pig (sold)
Old 11-19-2012, 03:52 PM
treerootCO's Avatar
Event Coordinator
AC idler pulley is usually the first to go...
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 11-19-2012, 03:58 PM
Thanks guys...I'll run some tests tonight
Old 11-19-2012, 04:29 PM
muffler bearings squeaky again?
Old 11-19-2012, 05:09 PM
I ruled that out because it is at the wrong end...And I verified that the blinker fluid is full so I'm good there as well
Old 11-19-2012, 09:53 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
The A/C idler bearing is pretty easy to swap out. I got a Japan one at Napa. some people run without the alt idler pulley but I left it in.
Old 11-24-2012, 02:18 PM
Smog pump, alternator, AC compressor are all suspects along with the AC idler. The water pump will typically weep before it squeals, and the PS pump will spew before it squeals.
Old 11-25-2012, 10:03 AM
My money is on the AC idler pulley. If I recall its about $60 from CDan for OEM.
