Old 11-27-2012, 11:29 PM
You beat me to it, Farnham.. was going to post almost the exact same thing.
great tech thread though, dang! almost wish I had a 2f..
I rebuilt the F on my '71, put it back in there and I swear it is even louder than it was before!
Old 11-28-2012, 09:20 AM
The point of EGR is to suck in burned fuel mixture to slow the combustion of the regular air/fuel mix. Slowing the combustion lowers the temps and creates less NOx. Some vehicles can suffer spark knock after disconnecting the EGR, but it's not common on 2Fs, because the compression isn't very high to begin with. You can leave all the equipment in place (for a visual) and plug off the manifold port, if you want. If you have removed the EGR vacuum line, the EGR will not open and exhaust will not flow through that tube.
If I were desmogging, I would put a BB in the EGR line, be sure the EGR valve is actually shut, and cap off that rear manifold port, to prevent current and future leaks. Many people cap it off by dropping a slug of steel in there and welding it in place. You can then bolt the tube right back up and it will look stock/OEM.
Old 11-29-2012, 06:11 PM
bigcity25's Avatar
bigcity25 bigcity25 is offline
Well after looking at my engine bay today the EGR vacuum is capped off. Guess I never used that and tells me I don't need it. So next step is to do some digging,remove and cap that off.
Jeff Billingsley
Denver Colo
7/70 Fj40
desmogged 2f, 4 speed
TLCA #21898
