Old 12-18-2012, 10:20 AM
bomber22's Avatar
bomber22 bomber22 is offline
Default fj60
just wondering, what is the best year for a fj60[in your opinion] and why? what are the differances if any? I hear 85 thru 87 are the best.
Old 12-18-2012, 10:25 AM
It depends..... There are actually very few changes in the FJ60s from '82 thru '87. The biggest change is in the tranmision - the '85 thru '87 had the 4 speed with a spacer that is the same length as the 5 speed which makes the swap easier.
The engine and emissions systems are identical in the 60s. However, the state emissions requirements change ove the years with lower allowable pollutants in the late models. It has become pretty difficult to meet the Colorado '87 standards with a carbed 2F. If you're planning the swap out the engine, YRMV.
It'll be easier to maintain and license a stock '83 than an '87 although it'll likely have more rust.
Old 12-18-2012, 01:07 PM
Later models had headlight washers and some early models were lacking a few small features. I think more earlier models were brown, based on what I see, and brown isn't most people's favorite color. I'd look for any FJ60 that had new springs/suspension, since all will need suspension by now.
Old 12-19-2012, 12:04 AM
cruiseroutfit's Avatar
cruiseroutfit cruiseroutfit is offline
Wasatch Cruisers
Along with the spacer style H42 (often called H42-Long), the t-case went from a 34mm idler shaft to a 38mm idler shaft with some other internal 'beefening'. Not that there are any major issues with the 34, just that the 38 is stouter.
All changes aside, my recommendation is the same as that for 40 Series shopping... Buy the cleanest body/frame/interior rig you can find, the rest is pretty easy to fix
Kurt Williams
Cruiser Outfitters
Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
Please call or email for pricing, tech, stock check, etc
Join us on Facebook
