Old 12-27-2012, 03:42 PM
Default CCOT's Rear Hatch Handle vs OEM
I just got back from CCOT. I broke the handle on my rear hatch the other day, and cast/chromed parts like that are pretty easy to make as good or better than stock. Given that, I figured it was worth checking into their reproduction to see how it compares to the OEM equivalent. Since I had them both in my hands side by side and I was told it was OK, here's a little writeup comparison for the greater good.
On the surface, the differences are pretty thoroughly negligible. The only readily visible difference I saw was a logo ("AIM") on the inside of the aftermarket piece. It looks to be the same type of chrome, weight was the same, major dimensions are the same, etc. etc. The way these parts are made, that's REALLY easy to do if you have an original piece in your hands. They are made "over seas", which I think can only be assumed to be China. Point OEM.
(aftermarket on bottom)
Closer inspection yielded the following differences:
(aftermarket on left for the rest of the photos)
The surface that makes contact to with the internal mechanism is smoother on the aftermarket piece. This is a positive in the aftermarket pieces favor, as the plating on this friction surface can be quickly and easily worn and invite corrosion. Point aftermarket.
There was a visible spot in the chrome plating where there was not complete coverage. This is more or less standard if you don't have the resources of a huge company (specially made chroming jigs), and does not represent a really negative point unless it's visible. It has the benefit (in my mind) of revealing the chroming process used (triple plating). Cheap chrome is just chrome on the pot metal, which doesn't always adhere very well ond tends to flake off quickly. I suppose you might be able to pull the piece partway through the chrome dip and reposition the attachment point on the piece, but you open the surface up to contamination (not a huge concern), the chrome is thin in two places (not a huge concern), or you could just have one spot without the final plate in a non-visible non-critical place (not a huge concern)... This was not present on the OEM piece. Point OEM
The slot for the lock lever is slightly different between the OEM and the aftermarket piece. The OEM slot is smoother and rounded verses the aftermarket piece having more squared corners and shoulders. This looks to be a difference in manufacturing processes; specifically, the OEM piece looks to have the slot cast and the aftermarket piece was either cut after casting, or the mold itself was cut. The aftermarket slot might also be marginally narrower, but I can't confirm that (hopefully I can be forgiven for not bringing calipers with me). This is of no concern whatsoever as the function of the slot is in no way compromised. In fact, the thinner slot of the aftermarket piece would likely be preferable in comparison since the slot is so much wider than the locking lever and lessens the play in the handle when locked. Again though, this difference is so minimal (maybe half a millimeter) as to not even be worth that amount of consideration. Point aftermarket.
Finally, the aftermarket piece has more prominent casting tails on the backside of the arms. The OEM casting either has a more precise amount of pot metal poured into the molds, or more attention was paid to grinding them smooth. This can easily change from piece to piece, and is thus not really worth much attention. Point OEM
Aside from the differences pictured, there were minor differences in the overall smoothness at the casting level in various places on the non-visible parts between them. Neither was better or worse/more or less than the other in this regard (and were so minor that I couldn't get photos to work out). Draw.
I plan to make various changes to the drivetrain and I'm not doing any sort of concourse restoration, so my OEM loyalty only goes so far as quality and performance are concerned. Additionally, the number of parts of this type sold and the profit earned thereby are not enough to keep Toyota in the game; in fact, I'm given to understand that the supplies of these types of parts are finite and limited to what has been produced and is being held in warehouses somewhere... Maybe, maybe not. Regardless, it makes sense to cast dollar votes to those enterprises willing to produce quality parts for smaller audiences after Toyota has left the game so we can continue to keep our trucks on the road. Point aftermarket (YMMV).
Finally, it's half the price. Not normally a decision maker, but it sure is nice. Point aftermarket.
Old 12-28-2012, 12:10 AM
cruiseroutfit's Avatar
cruiseroutfit cruiseroutfit is offline
Wasatch Cruisers
Great writeup! I'd be interested to see how it works out for you long term. For many years we offered the aftermarket cast units however they seemingly failed more often then the OEM units, in nearly every case breaking at the notch for the lock lever. The rounded edges of the OEM unit could offer less of a stress riser on the cast? Its hard to compare as it really comes down to how the rear hatch is adjusted. If the latch mechanisms are super tight and the handle is pulled too hard to open, either of them will break.
Fwiw, shop around... the OEM is only $20 more at some places
Kurt Williams
Cruiser Outfitters
Your original outfitter for OME - ARB - AA - Safari - Helton - Engel - Since 1992
Please call or email for pricing, tech, stock check, etc
Join us on Facebook
Old 12-28-2012, 10:12 AM
I bought it. I posted the same review on mud and heard the holes need massaging. That can happen due to the original being chromed and to tight tolerances and the added thickness of plating. The holes looked the same in person, but I didn't have any measuring tools with me to verify. I'll update when I get home and put it in.
Breakage from something like this might have an awful lot to do its why they broke in the first place. My lift gate was tweaked, and I had just got it mostly sorted and was abut to grease everything when it broke. I don't expect the handle to last long if I just toss it right back in as is.
I figure if it breaks its not a huge expense. Toyota supporting these as long as they have is certainly a blessing, but the quality aftermarket needs our support if we're going to be supported too in the long run.
Old 01-04-2013, 01:59 PM
I finally got some time to mess with this further. I don't know what the issue may have been in the past for the hardware not fitting in the handle, but I had no issues whatsoever. Maybe there is a minor difference in vintage or something, but mine fit like a glove. I still have to adjust and grease things, so time will have to tell as to whether it's fragile or not, but I have very serious doubts that it would be given what it is.
