Old 01-08-2013, 09:38 AM
Default 80 series rear sway bar frame mount
Does anyone know when the 80 changed the rear sway bar mount (to the frame) from the "hanger style" mount to the bottom of the frame mount? Mine is a 4/96 and has the bottom of the frame mount, so I assume this is newer style? Anyone know when the change occurred?
Mine looks like this (picture has drop bracket for lifted truck) - note the link on the right side of the picture where the sway bar mounts vertically into the bracket.
Edit: If anyone has a stock, straight rear sway bar for an FZJ80, let me know.
Old 01-08-2013, 10:00 AM
coax's Avatar
coax coax is offline
I don't have any first hand experience, but slee lists out the dates of the different drop brackets on their website, if this helps?
http://www.sleeoffroad.com/products/...es_spacers.htm
-Corey
'74 project pig (sold)
Old 01-08-2013, 10:20 AM
treerootCO's Avatar
Event Coordinator
8/95-1/98 is the new style shown in your picture above.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 01-08-2013, 12:35 PM
Thanks for the info.
Does anyone know of any local sources/part outs? I'd prefer not to pay for shipping since it's a large, bulky item, and it seems like sway bars tend to be retained with a rear axle assembly rather than sold separately. Mine is bent up pretty good...
Last time I was at Blake's they had several '93 and '94 80's, which won't work for me per the above.
Old 01-08-2013, 01:14 PM
sway bar is the same. just the links to the frame are different
Old 01-08-2013, 02:03 PM
treerootCO's Avatar
Event Coordinator
I am going bigger on mine with the tent setup. 30mm from Whiteline
http://www.whiteline.com.au/product_..._number=BTR46X
www.root45.com
TLCA #14133
Old 01-08-2013, 02:53 PM
Nice. I should look.at work one of.those since mine.was.all bent.to crap.too. sometimes i think it'd be nice to be less tippy
Old 01-08-2013, 05:56 PM
Doesn't Zettl have a spare set in his garage?
Old 01-08-2013, 06:04 PM
Jacket, Sorry that I didn't see your request for the sbar at the bottom of your post. I don't use mine as I rotated my rear axle up to save the drive shaft from rock abuse. I'll scare up another if I ever need it....or better yet I'll use an Anti-Rock on which would give me adjust-ability while getting it up out of the weeds.
KØUBN
Old 01-08-2013, 11:50 PM
Ha!!
No spare sway bars in my stash...3rd row seats, LX body panels, and a drive shaft
