Old 01-25-2013, 07:45 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Default Overheated?
Soooo on my way home tonight I look at my cluster and my temp gauge is PEGGED in the red cycle the ignition off while coasting and let it drop to cold before letting the truck bump start. Stays at operating temp. Cool. Look down again and pegged it may be a bad sensor, but I'm not taking any chances. Anybody near hampden and Sante fe have a good scan tool with data lists? I think I wanna check my actual temps before concluding on a sensor.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 01-25-2013, 11:44 PM
loudbay loudbay is offline
If it went down to cool for a while, when you let the motor cool down, wouldn't the sensor be good?
Old 01-26-2013, 12:25 AM
baja1d's Avatar
baja1d baja1d is offline
With the cool weather I'd guess a bad sensor as well but a new thermostat & radiator flush isn't going to hurt.... I'm assuming your radiator is topped off, could be a ruptured hose.
Travis Hurley– Owner/ C.E.O.
Old 01-26-2013, 09:01 AM
Squishy!'s Avatar
Ya topped off and still full. This is the 3.4 swap I just finished in September so the coolant and most of the hoses are new.
No the engine was off for 15-30 seconds tops.
-Justin Morgan,
TLCA #23166
Old 01-26-2013, 09:10 AM
Gotcha. I say you warm her up and see how hot the radiator hoses are by hand. I really don't know anything about these sensors, but a lot temp sensors are dummies, and really just show cold, not cold, overheating. I would start here, easy and probably pretty cheap.
Old 01-26-2013, 11:27 AM
I'm at work today if you want to stop by.
Old 01-26-2013, 06:06 PM
Squishy!'s Avatar
Ah dang. Missed ya.
-Justin Morgan,
TLCA #23166
Old 01-27-2013, 10:57 AM
Not necessarily. could be faulty connection, could be faulty ECU. Never jump straight to a conclusion, simply start eliminating possible causes until the root cause is found. Always start with the cheapest/easiest tests.
Old 01-27-2013, 01:42 PM
Squishy!'s Avatar
Right. It's why I'd like to look at what the ECU sees first. I've seen temp sensors short internally before especially once it reaches a certain temp. I may do the boiling water test with a thermometer and an ohmmeter. Quick and simple.
-Justin Morgan,
TLCA #23166
Old 01-27-2013, 11:48 PM
An infrared heat gun would tell you a lot about the cooling system, too.
