  #101
Old 04-08-2013, 11:34 AM
J Kimmel J Kimmel is offline
Ya me too, that's why I had him do it. Should be easily accessible for service but it is doubtful ill ever need to
  #102
Old 04-10-2013, 10:28 PM
finished my dash, kept it real simple...I also made an adapter for my air filter tonight. Cut a plate and welded on some 3" exhaust pipe and put this filter on there.
should be all set to start up this weekend Its only been almost a year
I'm getting down to odds and ends and cosmetic stuff
  #103
Old 04-10-2013, 10:33 PM
baja1d's Avatar
baja1d baja1d is offline
Man that looks great
Travis Hurley– Owner/ C.E.O.
  #104
Old 04-11-2013, 01:27 AM
It looks awesome although there is still some mintruck there. Need to go back in and cut deeper!
KØUBN
Colorado Trail Patrol
Stay on the Trail!
  #105
Old 04-11-2013, 07:53 AM
Says the guy who's been slowly adding mini truck to his land cruiser!
  #106
Old 04-11-2013, 07:54 AM
Great work Jeremy!
  #107
Old 04-11-2013, 08:46 AM
Thanks, its moving slowly but last night seemed like a good amount accomplished. Wiring will be all wrapped this weekend, and I *think* aside from shock tuning and leak mitigation the bulk of whats left is cosmetic. Hopefully it warms up a bit here very soon so I can start painting tubes and stuff...gotta bedline the interior then I can permanently mount the seats and belts.
I'm really starting to look forward to Moab and then Rock Junction at the end of May
  #108
Old 04-14-2013, 01:01 AM
It runs
First try almost all new wiring
  #109
Old 04-14-2013, 03:35 AM
RockRunner's Avatar
Awesome Brian does know his stuf!
Thanks T aka Tom KR0MPS
TLCA #6136
  #110
Old 04-15-2013, 09:37 PM
little more done tonight
I sanded the fenders good and shot some primer on them, I also trimmed them out for my LED's in the front and got those mounted. Yesterday I put some bondo on the rears, I think I need another light coat over the gas door I welded over. I apparently mixed up my ram assist lines, so I fixed that and bled out the system.
Here's one for someone who knows more than me...I filled the radiator with coolant and fired it up. I left the cap off, and let it run to get up to temp. It finally got I guess to temp and it started spewing coolant, like a geyser I shut it off and it stopped. Then I put the cap on, and repeated. I opened the cap once I shut it off really slowly and then re-filled and it seems ok?
What would cause that? I've seen plenty of times where the level will just drop when the t-stat opens and you add more, never saw old faithful
thanks
