Old 02-02-2013, 03:48 PM
Default How to remove C-Clip off end of axle shaft
Okay, so I'm trying to remove the small broken axle shaft in my front diff carrier, but I can get anything inside the hole to spread the c-clip off so I can remove the shaft stub out of the carrier. Any ideas how to get that C-Clip off, so I can remove the shaft from the carrier???
Thanks,
CJ
C.J. Bowen
2015 Jeep Rubicon Hard Rock, 2000 Jeep Grand Cherokee
Old 02-02-2013, 06:02 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Is it in the truck or on the bench?
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 02-02-2013, 06:06 PM
Bench
C.J. Bowen
Old 02-02-2013, 06:10 PM
Squishy!'s Avatar
Center the clip on the shaft and gently prybar the end into the spider. I've used heavy duty magnets at that point to pull it through and out. I haven't had to use that trick on an IFS diff yet though
-Justin Morgan,
TLCA #23166
Old 02-02-2013, 06:27 PM
Its a detroit truetrac with the ring gear on it..
C.J. Bowen
Old 02-02-2013, 06:47 PM
CJ, this is an early IFS diff yes?
If so, the best (easiest) way to do this is to use a piece of scrap metal, and some JB weld, the fast setting stuff.
You adhere the metal to the end of the broken axle, and once it has fully set (IIRC the quick set stuff is 5-10 minutes), you pull the metal and the shaft out. Those clips are next to impossible to remove in-diff. It works best to use a something you can pry off of. On the trail, I used a cheap box wrench with one end cut off to pull a shaft from a guys truck. got my pry bar into the closed end and it popped right out.
Or, that has been my experience. Best of luck!
Old 02-03-2013, 12:45 AM
Squishy!'s Avatar
I pulled a c-clip and nub out of an 4runner front diff before. I think it was in Moab on Rachel Romer's Runner. I used a couple of small picks to hook it and pull the clip out then used a magnet to slide the nub through the side gear. Sounds simple but I think it took a couple hours and a couple
-Justin Morgan,
TLCA #23166
Old 02-03-2013, 09:22 AM
How did you get to it? IIRC, the true trac is a housed unit (not open spider gears, so no way to get at the back end of the axle), but I recall Rachel's 4runner had an ARB in the front.
How did you get the picks into the actual unit?
Old 02-03-2013, 09:50 AM
Squishy!'s Avatar
Through the side gear splines and axle shaft opening. It was a PITA.
-Justin Morgan,
TLCA #23166
Old 02-03-2013, 08:13 PM
Whoa. Okay, my hat is officially off to you. I would not have had the patience for that!
