Old 02-03-2013, 08:18 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Not much of a choice. Had to be done.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 02-03-2013, 08:46 PM
I will invest in some needle nose pliers for C-Clips.....
C.J. Bowen
2015 Jeep Rubicon Hard Rock, 2000 Jeep Grand Cherokee
Old 02-03-2013, 09:50 PM
Squishy!'s Avatar
And a small long pick set.
-Justin Morgan,
TLCA #23166
Old 02-05-2013, 08:51 AM
The JB method will save you a lot of time. You don't need to get the clip off that way. It will just pop out like you would do if the axle was whole.
Old 02-05-2013, 12:35 PM
Default output stub stuck in a tru-track
I bought a new seal, then welded a a bolt with a washer already on it to the stub. Put my slide hammer on that and it popped out on the first try. The spring clip stays on the shaft.
seal puller to pry out the old seal.
tapped in the new seal, popped in new stub shaft. Sold the tru-track.
KD0FDS
Stephen
