Old 02-02-2013, 11:32 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Originally Posted by MountainGoat View Post
My 80 had a clunk which behaved exactly like you describe. Turned out to be worn splines on the rear driveshaft, causing enough rotational play to clunk on change of direction under load. It was diagnosed and repaired by Bill at Bill's Englewood Driveshaft with a driveshaft rebuild. Hasn't repeated since.
Yup that's the one. Nak you could remove the rear shaft, lock your center and see what happens. Or swap in a donor shaft.
That's what she said.
-Justin Morgan,
TLCA #23166
"Apollo"-1988 Hilux, 1999 3.4L, Supercharged, 2.1" URD pulley, URD 7th injector, 2 1/2" Magnaflow exhaust, SOLD
"RedChili"-1987 Super Beast
Old 02-03-2013, 08:57 AM
x2 on the cool video
I would toss in another vote for splines on the drive shaft. Each change in direction causes the splines to bind slightly due to wearing and/or lack of lubrication in the slip joint.
If you think it's coming from the front, then pull that drive shaft and do the same test. And then try the rear next if the noise is still there.
Old 02-03-2013, 03:05 PM
Well I got my skid plates and front driveshaft off, and my clunk is unchanged. guessed wrong... will get it cleaned up and reinstalled, then tear into the back... stay tuned!
Old 02-03-2013, 03:56 PM
Squishy!'s Avatar
Pullin for ya!
-Justin Morgan,
TLCA #23166
Old 02-03-2013, 05:48 PM
Bummer, I was betting on a front CV joint.
So how different is a 100 rear shaft from an 80 rear shaft?
Old 02-03-2013, 06:03 PM
They both feel about the same heavy. But it's not the driveshafts... I spent the last 4 hours on this, had them both off, apart, cleaned splines, greased u-joints, put them back on and the clunk is completely unchanged. In fact it may be a little louder now, as I left my skidplates off until I figure this out.. hmm.
Check out how much grease I was able to squirt out the zirc hole on the rear... I only can take credit for maybe 6 squirts of that.
Old 02-03-2013, 06:05 PM
You can literally feel it under your feet, just when you hit the brake. Two new videos... one from each slider
movie 3
movie 4
Old 02-03-2013, 07:26 PM
Squishy!'s Avatar
I would say its gotta be the pads then. If you are only hearing it when you press the brakes when changing direction that is the only possibility left I can think of. How was your pinion play?
-Justin Morgan,
TLCA #23166
Old 02-03-2013, 07:43 PM
So if I have too much slop in my pads, how do I get rid of that- bleed it? Or shove more shims in there?
Pinions seem fine, they didn't have any in/out play that I could feel.
Old 02-03-2013, 07:48 PM
Squishy!'s Avatar
I would say its the mounting hardware for the pads. There are tension springs that help keep them centered and absorb the shock of directional change. It's possible it could just be at one of the pads. Wiser techs than I may have other ideas as well.
-Justin Morgan,
TLCA #23166
