Old 02-08-2013, 04:44 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Also, that's what she said.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 02-08-2013, 04:53 PM
I wonder if it'd help oil in a motor get to the pan quicker...
Coat the inside of a block with it, rods & crank too (non bearing surfaces of course)
I bet it would work well! On race engines we always used commercial grade epoxy to fill any low lying areas in the lifter valley and along the pan rails, then we would coat the inside of the block with silver epoxy paint. It worked very well as when we had to pull them apart they stayed very clean and if the block was stressed anywhere you would spot the cracked paint quickly!
Old 02-08-2013, 04:54 PM
maybe it'd help with cold starts by keeping fuel atomized better in the intake? Spray it in that bugger?
sure the potential for catastrophe might be high, but who cares.. it's in the name of science
  #24
Old 02-08-2013, 04:56 PM
Fuel might break it down because of it's solvent qualities.....not sure if that would be good for keeping the valve seats sealed. As long as it was before the injectors It might do well.
  #25
Old 02-08-2013, 04:59 PM
Squishy!'s Avatar
X2, but it would be cool to test on an engine nobody cares about.
-Justin Morgan,
TLCA #23166
  #26
Old 02-08-2013, 06:08 PM
Very cool... Where would you spray this coating?
I can't believe no one has said this yet in answer to the question...Where you I spray this coating? On the entire inside of Davis' 100 series
  #27
Old 02-08-2013, 06:25 PM
PabloCruise's Avatar
Try sharing the video this way....
Silly question - but how do you share youtube videos that way?
Whenever I try it I get a messy long link...
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
  #28
Old 02-09-2013, 12:01 AM
Allison just had an idea...
Exterior of a car.
  #29
Old 02-09-2013, 04:10 AM
click the red "Tube" button then paste in just the YouBube vid identifier number between the boxes. In the case of this YouBube the number is IPM8OR6W6WE
  #30
Old 02-09-2013, 08:05 AM
Abrasion resistance would be my question - how long does it last on the surface of a concrete chute (or inside my wheelbarrow, or on the bottom of my FJ40)...?
