Old 05-23-2013, 02:57 PM
Perfect. I just dumped a couple of gallons of Delo into my 40 last week 'cause they were out of the Rotella.
Old 05-26-2013, 12:08 AM
jps8460's Avatar
jps8460 jps8460 is offline
Vice Commander
From a background in racing, I ran comps break-in adative after a build with radical lobe profiles and a Ford lifter where it is absolutely critical.......since my 2f rebuild I've ran rotella-t. I polished my journals to the low side of the tol. (ie. larger clearances). I'll e sure and let you guys know when using rotella-t fails me.
Old 05-29-2013, 10:57 PM
I looked for and could not find any Accel at wally world or at Carquest so I ended up buying another bottle of Rislone ZDDP additive.
  #24
Old 05-30-2013, 07:53 AM
weird. i've had no issues finding it. commerce city, tower road and stapleton all carry it.
  #25
Old 07-19-2013, 07:12 PM
NoVaGator NoVaGator is offline
Thread resurrection...
I run Brad Penn oil in my '88 911 for the higher zinc content. It's about 6.25/qt when you buy by the case.
  #26
Old 07-19-2013, 08:05 PM
I just bought a whole bunch of Ace Hardware private label at $2 a quart on sale, it is normally around $4.50 or so. I figure for that kind of discount, I can justify the $6 a bottle for the Rislone additive.
  #27
Old 06-11-2014, 08:43 AM
Default Now, with more zinc....
Thread resurrection again. The 10w-40 Accel oil bottle at Walmart has been revised again and now says 'Contains at least 1100ppm Zinc'. Still $2.67/quart.
  #28
Old 06-11-2014, 11:40 PM
The Evergreen Walmart doesn't even sell quarts any more, they've gone to the big jugs.
  #29
Old 01-09-2015, 11:41 AM
Another modern oil (not SF rated) with high zinc and high phosphorous.
Quaker State 'Defy' motor oil for high mileage vehicles. Zinc 1071 PPM, and phosphorous 990 - outside the normal spec.
http://www.pqiamerica.com/June%202014/QSDEFY.htm
  #30
Old 01-15-2015, 08:58 AM
ToyodaTocco's Avatar
ToyodaTocco ToyodaTocco is offline
I just changed my oil and put the quaker state defy in. I'll let you know how it does. I picred it up at Walmart for $15 and some change for 5 quarts.FYI... It is a synthetc blend, I didn't notice it until I had half the jug in my engine.
Bill
TLCA #23154
1984 Toyota Pickup "The Geisha" 22RE conversion
1994 Toyota 4runner -Verrrrrryyyyy Long-term Project vehicle
1994 80 Clifford's back again
