Old 03-03-2013, 10:46 AM
kurtnkegger's Avatar
Jeff, this might fall in to the paint stripper catagory...but I've had decent results using graffitti remover to soften some materials that other chemicals wouldn't touch (like concrete floor patch removal from a metal blade)
Old 03-04-2013, 06:05 PM
Originally Posted by rutbeer View Post
Have you tried cleaning it with a ball peen hammer yet?
The only mechanical method I have tried so far is wiping with chemicals such as goo gone and ammonia based window cleaner, and solvents.
Old 03-04-2013, 06:07 PM
Originally Posted by J Kimmel View Post
you'll want to use a razor to scrape off the goo, but this is the method I learned from a very good friend who tints for a living.
The thing is, it isn't sticky, it is hard as a rock. Most likely from decades of Arizona sun and heat. That may well be why the usual methods mentioned on web sites have not done a thing.
  #24
Old 03-04-2013, 06:08 PM
In the list of chemicals I tried were aircraft paint stripper. Didn't do a thing for the film that was left after I peeled the tint off, but....I can't remember
  #25
Old 03-04-2013, 06:34 PM
Did you see Farham's suggestion? Those things seem to take off just about anything, including stuff you don't necessarily want taken off
  #26
Old 03-04-2013, 09:34 PM
I did, but I am unsure about using abrasives. There must be a better answer with chemistry?
  #27
Old 03-05-2013, 07:00 PM
bomber22's Avatar
bomber22 bomber22 is offline
i just did the front windows of the tundra, i used a heat gun to help loosen the film and the glue then used goof off and 0000 steel wool to clean the glue off then cleaned the windows as required with viniger/water mix and paper towel worked really well.
  #28
Old 03-05-2013, 07:29 PM
Is goof off different than goo gone?
  #29
Old 03-05-2013, 10:26 PM
bomber22's Avatar
not sure, i bought the spray can type at home depot.
  #30
Old 03-06-2013, 10:53 AM
OilHammer's Avatar
Goof off I think is xylene, at least the old one was IIRC....and goo gone is citrus based with a little petroleum.
Xylene is far more toxic, probably causes cancer in lab rats, and therefore, actually works.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
