Old 02-27-2013, 07:58 AM
Dirt Claude Dirt Claude is offline
Default Birfield/Aisin Hub Issue
I'm wrapping up the front axle rebuild and disc brake conversion on my 72' FJ40 and ran into a slight issue. The Birfield shaft appears to be too long and won't let the manual dial hub mount onto the hub body.
Here's where I'm at:
- I'm told all the conversion parts came off a Toyota mini-truck, Birfields & hubs as well.
- I installed the mini Birfields onto my 72' inner axles.
- After grinding the lower portion of the axle ball to accept the slightly larger Birfield, the Birfield bell appears to be fully seated inside the axle ball.
- All gaskets and brake backing plate were installed.
- There's about a 1/4" gap between the hub body and the snap ring on the end of the axle shaft.
My first guess is that I have the "short" hub and I need the "long" hub. I wasn’t even aware there were different size hubs until I came across a picture comparing the two. What vehicles came with the long hub?
My second guess was that maybe these new Birfields I have are 76'-78' as they are longer than the 79'+ Birfields. But that couldn't be as I did have to grind out the axle ball to accept the new larger Birfield. If it was 76'-78' then the 72' axle housing would have accepted them without grinding?
Brad Cockrell
72' FJ40
00' 100
01' Taco
Old 02-27-2013, 08:10 AM
Huh. From your description of all the minitruck parts I would have thought everything would work. The longer body Aisin/Asco lockouts came on '76-'78 FJ55s, and I think your only other option would be to find the longer body Warn lockouts for '76-'78 FJ40s/FJ55s.
I don't know if it matters, but is the lockout in the locked or unlocked position when you are trying to install it?
Old 02-27-2013, 08:15 AM
Are not 76-78 axles longer than the rest? AFAIK the mini truck hub bodies are all the same length, solid axle or IFS. Maybe you need the silver faced hubs from a Pig?
Also the clip in the end of your axle on my truck is right up against the inner sleeve of the hub (what a PITA to get that on, I have to use a cheater bar). That seems to me to indicate the hub is too short, right?
Old 02-27-2013, 08:27 AM
DenCo40 DenCo40 is offline
I just went through this exact thing. Currently I am installing late model Cryo'd birfs with short Aisin hubs. I have all the parts for it and just waiting for a nice day to change out the parts. I will be getting rid of my long birfs and long body Warn hubs when I am done. In case you are interested.
Long birfs 76-78 will not work with short body Aisin hubs as you can see. Long body Aisin hubs (pig hubs) are out there you just have to find them. One solution that you might be interested in that I saw on MUD, was to cut 10mm off of your long bifs and have a new C ring groove machined in.
http://forum.ih8mud.com/40-55-series...-question.html
2007 LX470
KD0WJN
Old 02-27-2013, 08:38 AM
I actually removed all the guts from the lockout and just used the dial, the back of the dial is hitting the axle shaft.
Brad Cockrell
72' FJ40
00' 100
01' Taco
Old 02-27-2013, 08:43 AM
That's been my experience with the c-clip too, but with this setup I've got almost a 1/4" gap between the clip and the hub.
Brad Cockrell
72' FJ40
00' 100
01' Taco
Old 02-27-2013, 09:34 AM
Thanks for the link Jim, I searched MUD quite a bit last night but didn't come across that thread.
So that reconfirms my thought, the birfields I have are likely 76'-78' and will not work with the short lockout hubs. At this point I think I'll try and source some 79'+ birfields rather than stick with the older ones. 79'+ should be easier to find, they're more common as a trail spare, and I can keep my short hubs so they can stay out of the rocks. I may also trim down my current ones and have the new c-clip groove machined in.
Brad Cockrell
72' FJ40
00' 100
01' Taco
Old 02-27-2013, 09:51 AM
Telly Telly is offline
I have a short birf if you are interested. See this thread.
http://www.risingsun4x4club.org/foru...ad.php?t=18704
Old 02-27-2013, 10:55 AM
Thanks for the offer, I may take you up on it.
Brad Cockrell
72' FJ40
00' 100
01' Taco
Old 02-27-2013, 11:43 AM
RicardoJM RicardoJM is online now
Brad, I believe that I also have a birf that will work for you.
