Old 03-01-2013, 10:35 AM
Or maybe plug wire routing? There is a corona that forms around them when the cylinder is fired, which can short to adjacent wires or to the block. Are they held fast and have you routed them so they don't twist together?
Could be a problem that is worse in the winter than summer. Remember electrochemistry, fresh water does not conduct well but salt water does. What makes up road spray in the winter? Magnesium chloride is a salt and makes an electrolyte when dissolved in water. Might even be fine in the rain or water crossings but the increased ionic activity puts whatever problem, cracked cap, failing wire, etc. over the edge.
Old 03-04-2013, 08:09 AM
Truck sounds like it is a lemon. I'll give you $5 for it right now.
For this rusty ol' rattle trap? You're too generous
Originally Posted by FJBRADY View Post
Nice, next time give it a running start and floor it.
This is what ends up needing to happen when I try that...
Could be plug wires or the coil wire. Even if the dizzy stays dry inside, if the plug wires get wet they will short to ground and the plug for that wire wont fire. If it goes from not running to running in a relatively short time (less than 30 mintes) look for these types of issues. The plug wires dry out faster due to the engine heat and exposure to open air. If you get water inside the dizzy, it usually takes longer to dry out.
That sounds feasible, and exactly what I was thinking too at the time. I guess I need to use some dielectric grease at the plug connections?
I doubt this is the problem - I'm using factory wires with wire clips etc. I'll look at it a little closer though and make sure I'm good
Thanks for the suggestions all - well, except for Brady
Old 03-04-2013, 08:42 AM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Your welcome
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 03-04-2013, 08:55 AM
So I had an opportunity after work yesterday to bust snow into my in-laws place. They live up near Conifer so they've gotten about 20" of fresh in the last couple of storms.
If you listen to me talking, yes I know I'm a wussy
Man do you need some tires! Even Toyo's would be better than what you have! We could pass the hat at the next meeting.
Old 03-04-2013, 09:03 AM
Egg-zachary! I was taking a walk the other day and passed by a Bronco with what looked like brand new MT/Rs, and holy cow the tread is deep on those suckers! Mine are definitely way worn down!
But I'm thinking 33x12.50 for my next set - which means I need a lift! $$
Not to mention I can't decide if I should go to 4" or just go springover and 36s and be done!
Old 03-04-2013, 09:06 AM
36's would require bunch mo mula for gears, lockers, V8, fridge, etc....
Old 03-04-2013, 09:11 AM
LXBRADY's Avatar
Dats wat I got and have peek fun in the snow. Just floor it I say and leave the chains at home.
minus the fridge.
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 03-04-2013, 09:27 AM
Yep, yep, I know it $$
And my 2F was feeling none too powerful this go-round, that's why I couldn't take Brady's advice
So that's why I keep driving it as-is, trying to get by with what I have.
Old 03-04-2013, 09:31 AM
Sell the wifemobile and throw money at it.
Old 03-04-2013, 09:48 AM
I got nuthin'
