Go Back   Rising Sun Member Forums > Toyota 4x4 > 4Wheeling and Event Staging Area
Old 04-10-2013, 08:17 AM
Old40Dog's Avatar
Old40Dog Old40Dog is offline
In. Weather should be good too.
Dave can you program a Yaesu FT-2900R?
Dave K,TLCA#20150,KFØDOG,'69 FJ40-"Toyolet",'92 FJ80 {Isuzu diesel conversion underway} ,2011 Replica M416 w/RTT,'98 Taco Xtracab 4X4, Project='72 FJ40, '05 Passat TDI-DD.
Old 04-10-2013, 08:36 AM
Negatory on the FT-2900 Red Leader. The club has a couple of FT-2800s so maybe we have software or at least the cable. I'll check and see, if I can come up with it I'll bring it along.
The software and cable:
https://www.rtsystemsinc.com/FT-2900...ble-s/1897.htm
RT Systems is here in Colorado now, so an order comes the next day (or same day if you pick it up in Broomfield). I don't have a FT-2800 or FT-2900 otherwise I would buy it.
Edit to add:
I can probably also program VX-2, VX-5 and FT-60 HTs and there is a fair chance I might also be able to handle FT-7800 and FT-8900 (I have the cables). I could also do the FT-1802 and FT-2800, UV-3R and UV-5R if we have or find cables for them.
I have the CHIRP software, which is an open source GNU programming platform that attempts to move towards a unified programmer with vendor specific drivers. In my experience it has mixed results but I'm willing to try cloning if you are.
http://chirp.danplanet.com/projects/chirp
Old 04-12-2013, 07:29 AM
I will be there as close to 9AM tomorrow as I can and will plan to stay until 1PM. After party at Big Choice, so if you come late and no one's at the first location go to the fall back position. Tunes and fixes done at BCB enjoy no warranty protection. :-)
Simplex talk in will be 147.420MHz (Rising Sun #3).
Backup will be 147.540MHz (RS #4).
Repeater will be the 147.225MHz/+0.600/107.2Hz CRA machine since it's linked to 145.460/-0.600/107.2Hz in Boulder, 145.160MHz/-0.600/107.2Hz in the Springs.
Backup will be 145.145/-0.600/107.2Hz.
CB is channel 4
Backup will be channel 3.
If anyone wants to try UHF, I usually monitor the RMRL repeater at 449.450MHz/-5.0/103.5Hz but this will be on a secondary basis, no promises.
  #24
Old 04-12-2013, 09:01 PM
Holy smokes this is the farm pig and brown eggs run meeting in longmont
I doubt i'll trek all the way up there. Anyone on the southside want to meet and we can talk to the other group up north? Be kinda cool to have 2 locations anyway...
WØREK
  #25
Old 04-12-2013, 09:38 PM
CardinalFJ60's Avatar
Default Soccer here, too.
We've got soccer all morning. I should be able to make it there by 11:45. I'll bring my mfj swr meter, and some random power pole stuff.
  #26
Old 04-12-2013, 11:03 PM
OilHammer's Avatar
Wes, why don't we do that. We can meet over near the Ham Radio Outlet on Evans east of 25. I need a new cable.
They don't open until 10am though, so food first.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
  #27
Old 04-12-2013, 11:04 PM
Old40Dog's Avatar
Out now! Still fighting a bad cold.
  #28
Old 04-13-2013, 06:54 AM
I suggest the Breakfast Inn, about a block west of Monaco on Evans.
  #29
Old 04-13-2013, 08:47 AM
South side 8:30 at orig pancake house dtc(bell view,25) then to HRO
WØREK
  #30
Old 04-13-2013, 11:23 AM
guys shout out in colo. connection if you can't hit the repeater above, will be listening
