Old 11-22-2010, 06:30 PM
74fj40's Avatar
74fj40 74fj40 is online now
Default Quest for fuel injection
Well I am going to give TBI a try on my 1f. I have debated buying a 2f, putting a 3fe head on it and what not, but unfortunately I don't have the time nor the money to do that as of right now. I have seen many sucessful tbi retrofits so I am excited to give it a try. It is going to be a long slow build as time is limited and money is tight! This thread is to keep me motivated, so please tell me your thoughts!
I picked up an intake from steve that had an adapter plate tig welded to it already, with a throttle body, and an air filter. It looks as though the throttle body is a remand or maybe even brand new, but I am unsure.
Anyways, I took it all into work today and took it apart, then I sand blasted the intake, and then brought it home and painted it. Also put in a little extra paint on the TEQ logo
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 11-22-2010, 06:32 PM
74fj40's Avatar
Here is the other pictures
1972 Toyota FJ40
[/font]
Old 11-23-2010, 09:05 AM
Looks spiffy. The multi-port injection of the 3FE is the bees knees, but you gotta do what you gotta do. Interested in seeing if this gives you the benefits of more power, better fuel economy etc.
I like you finishing touches on the TEQ symbol
Old 11-25-2010, 11:04 AM
farnhamstj's Avatar
cool
KD0GWO
Old 11-25-2010, 11:59 AM
74fj40's Avatar
Thanks guys! I found someone on pirate that is selling a brand new harness and computer preprogrammed for a 2f from affordablefuelinjection.com which I'm trying to pick up right now. that would be perfect and make this project easier!
1972 Toyota FJ40
[/font]
Old 11-25-2010, 12:11 PM
Is that computer going to give you ignition control too or just fuel? I went with megasquirt mostly because it allowed me to use a Ford EDIS-6 ignition module to contol timing advance. I mounted the missing tooth wheel on my damper with an adapter turned on the lathe, then welded a V/R mount on the timing cover to finish it off. Seems to work very well just turning it with the starter.
The 3FE port fuel injection probably isn't really worth the amount of extra effort needed to get it together, head, TB, induction, cleaned and tested injectors, etc. But on the other hand, the long runners are amazing on this setup and I had to go this way once I saw it.
BTW, that's a nice job you did on the TBI manifold. I probably would have bead blasted it and rebored the insides after welding it if I hadn't got distracted with the 3FE stuff first.
Old 11-29-2010, 08:51 PM
74fj40's Avatar
Steve- Thanks for the compliments. Ignition control would be controled by the ecm and ESC(Electronic spark control) either way I don't think I'll be using the electronic ignition control. I plan on using the factory toyota distributor and vacuum advanced. I will just use the ported vacuum line off of the throttle body. I will just have the ecm PROM Flashed to be used without it. I would like this system to be as simple as possible, and using an ESC will just make things more complicated.
1972 Toyota FJ40
[/font]
Old 11-29-2010, 09:09 PM
Looks like a fun project Manifold looks nice!
I was thinking of going this route with the 2f in my 60 a while ago. I think it'll be sweet hen you get it done. It'll run like a fuel injected truck!
Old 11-29-2010, 09:58 PM
It's your choice, but I think you're leaving a lot on the table by sticking with vacuum control of spark. There is IMO no better way to get the best combination of power/reliability/economy than full closed loop control of fuel & spark. But then you can always revisit the spark thing down the road after you get it running with just TBI control. Good luck with it, and keep us informed on your progress!
Old 12-01-2010, 08:20 PM
74fj40's Avatar
Not much to update. Scored everything I need for this setup from someone on colo4x4.org computer, all sensors, harness etc. for a pretty good deal! but havent picked it up yet. also scored a new fuel pump, and inline fuel pressure gauge from my boss at work.
1972 Toyota FJ40
[/font]
