Old 03-25-2013, 11:18 AM
baja1d's Avatar
baja1d baja1d is offline
Default Brake line clips
Have anyone ever seen these brake line clips? They're welded to both my axle housings & are 1.5" wide. If so, any idea what the other part that attaches to the brake line is called? Or where I could get it?Name:  ImageUploadedByTapatalk1364228186.687890.jpg
Size:  72.4 KBName:  ImageUploadedByTapatalk1364228199.452123.jpg
Size:  95.1 KBName:  ImageUploadedByTapatalk1364228211.052991.jpg
Travis
Travis Hurley– Owner/ C.E.O.
Old 03-25-2013, 11:58 AM
DanS's Avatar
DanS DanS is offline
Do you just run the brake line parallel to those things, and then zip tie between the two, or just attach them using a hose clamp?
Old 03-25-2013, 12:57 PM
Are those factory?
Old 03-25-2013, 01:00 PM
baja1d's Avatar
I have no idea. I'm currently running them parallel & using zip ties but I thought that there might be a bracket designed for the set up that was "more permanent"
Travis
Old 03-25-2013, 01:01 PM
baja1d's Avatar
Are those factory?
Doubt it. They're not on my other stock '76 axle. I think the PO added them in the rebuild
Travis
Old 03-25-2013, 01:26 PM
I've never seen anything like that OEM. Looks like a zip tie mount. Did it have hard or flex lines crossing the housing?
Old 03-25-2013, 03:57 PM
baja1d's Avatar
No idea. I'm planning on running a hard line.
Travis
Old 03-28-2013, 08:30 AM
LARGEONE's Avatar
LARGEONE LARGEONE is offline
Those were definitely added. I did something similar to run wiring on my truck.
Paul
KE0OLZ
1967 FJ40 - Nearly Stock
http://www.vrbo.com/322094
Old 03-29-2013, 09:51 AM
Those look like 1/2 of a chain link cut and welded to the housing. You can probably buy it at your local Depot, or Ace for a buck a foot or something similar.
Old 03-29-2013, 07:17 PM
LARGEONE's Avatar
I used the large Electrical Staples...cut them off and welded them. This way I can zip-tie to the staple and remove/replace as often as I like.
The ones on your axle are a bit larger than the ones I welded on, but same idea.
Paul
KE0OLZ
