Old 03-29-2013, 10:14 AM
Didn't want to pull the box off and had no plans to box the frame. But gusseting might be necessary and if that happens the box comes off and the frame gets boxed. We do intend this as our everday and road trip truck and expect at least a decade more service from it. The thing runs great and doesn't rattle or even have worn off switch labels and stuff. :-/
This truck probably won't even get an ARB or anything, at least no time soon. Heck, who knows, this one might not be around in 10 years because of the rust and Imelda gets her wings in a 3.4L swap...
I do need a rear bumper. Mine is still bright and shiny but has a dimple in it. I was thinking about getting one from Brian up at Front Range so I also get a receiver and shackle points at the same time. But the prospect of $600 and doing more frame resto than I thought, I put that on the back burner.
Old 03-29-2013, 10:15 AM
coloradobound's Avatar
coloradobound coloradobound is offline
Are you sure it was 2001? My 2002 doesn't have it but my dads 2003 does. The throttle bodies are definitely different.
2002 Tacoma DCab TRD, OME suspension, 1" Daystar Bodylift, ARB front bumper, Lightforce 170's, 20" led light bar, blacked out HID bixenon projectors, Slee Sliders, 33" Yoko's on 5th gen 4Runner wheels, TRD supercharger, exhaust, and trans cooler.
to do: snorkel, ditch lights on Cbioffroadfab brackets, flush mount lights in new rear bumper, rock lights, new retrofits in headlights, ARB fridge mounts in bed w power, hids in LightForce (or arb led knockoffs)
Old 03-29-2013, 10:18 AM
... The throttle body on my '91 has a channel parallel to the pedal actuated cable, which I believe held a second cable for the cruise control actuator.
That's basically how the '97 3RZ-FE is set up. I was kinda curious about the column buttons and indicator lighting though too. I'll call Toyota and see what's up.
Old 03-29-2013, 10:20 AM
...and Imelda gets her wings in a 3.4L swap......
Ooh! Ooh! Ooh! Sounds good!
Old 03-29-2013, 10:23 AM
Scott says no
Old 03-29-2013, 10:49 AM
The first year the ETCS appeared was 2001, but it is apparently very rare. Seems it's only Limited. It might also be a Taco vs. 4Runner thing, a lot of things show up in the 4Runner that are either rare or nonexistent in pickups. I think by 2004 all 3.4L engines had it, though. You are 100% correct, there is no question with or without, the throttle bodies, the accelerator cable, etc. are different.
Old 03-29-2013, 10:59 AM
Scott says no
There are aftermarket options that work the same way with a cable that pulls the throat plate and essentially ignores the pedal totally, so that might be a possibility. The only downsides I could see to them were (1) quality and (b) less tight integration. We'll see about the quality vis-a-vis the frame nonsense but integration seems to favor factory.
http://www.thecruisecontrolstore.com...003/toytac9504
Old 03-29-2013, 11:53 AM
Sounds good on the frame. Give a holler if you decide you wanna gusset or box it in.
Cheers!
Old 03-29-2013, 12:43 PM
Will do, thanks. I think for now I'm going to clean and coat it as best I can.
Old 03-31-2013, 08:02 AM
Cheers!
The more I think about the more I convince myself to do something. :-) I'm gathering stuff to clean up the rust, paint it and rustproof it. So might as well do some frame strengthening now before I coat everything and put the camper on it.
Yes, you are right Nakman...
From what I see fully boxing in the frame might be more work than I think is necessary, though (would prefer not to remove the box for one). You have more experience with Tacos than me. I'd want to retain the stock BPV, shock, gas tank and spare mounts.
I've also seen people weld reinforcement to the outside of the frame over the axles. Does this really help prevent the frame from rippling under the box? If so this might be an option that's easier and achieves some of the benefits. I'll probably order up CBI's plates, I like the looks of them.
http://www.cbioffroadfab.com/store/p...products_id=98
I also see some people reinforce the front frame horns. I might one day put a bumper on, but even if not, is this section of frame known to be weak in a non-SAS situation? What about the section that transitions down from the box to parallel under the cab, forward of the spring hanger? Isn't that the spot where most frames eventually rust and bend?
