Old 04-07-2013, 10:27 AM
kvanoort's Avatar
kvanoort kvanoort is offline
Default Factory Roll Bar Location?
I'm installing a Metal Tech Full Profile Cage into my '72 40 and need location measurements of the bolt holes for a factory roll bar on the wheel wells. My vehicle didn't come with a factory roll bar and the rear mounting plates for the cage use the factory bolt holes to correctly position the base plate. If someone could measure the distance of the roll bar bolt holes from the front and side edges on the wheel well and post them up I would greatly appreciate it. Thanks.
Kent Van Oort
Lafayette, CO
1972 FJ40 Current Project, 1978 FJ40 Sold Project, 1975 FJ40 High School Cruiser
TLCA #17904
Old 04-08-2013, 02:36 PM
Swing by this evening and we can take a look.
Old 04-08-2013, 06:07 PM
Look at the passenger side forward measurement, the top right hole is measured from the inside edge of the quarter panel. In reality, even with an aftermarket roll bar there's really only one way to orient it relative to the fender wells.
Old 04-09-2013, 04:01 PM
kvanoort's Avatar
Based on the measurements I took from Matt's factory roll bar and Jeff's CAD (Crappy Ass Drawing) :-), I have what I need to position the Metal Tech cage. Thanks Gents!
Kent Van Oort
Lafayette, CO
TLCA #17904
Old 04-09-2013, 08:56 PM
L43dean L43dean is offline
[/quote]
This needs to be a Rising Sun T-Shirt.
