Old 04-11-2013, 11:58 PM
Default Source for Lunette Ring?
I'm looking to source a receiver type Lunette Ring with a 3" hole, 6.25" overall diameter. The one pictured here from Northern Tool only has a 2.5" hole. Anyone have any ideas where to find one?
Old 04-12-2013, 06:57 AM
Not sure if you're gonna find a 3" lunette directly connected to a 2" draw bar. I think 3" rings are rated 20,000 lbs and higher, so even a Class V 2.5" draw bar would not be enough. The highest Class IV 2" is 12,000 lbs. The 3" lunettes on dump trucks and deuce and halves are I think rated to 60,000 lbs (etrailers has them, just $215).
My guess is you'll have to assemble it from a lunette plate with a draw bar adapter.
http://accessories.etrailer.com/search?w=lunette
Old 04-12-2013, 10:18 AM
That was my thought too. I probably should just pony up for a max coupler but I'm poor right now with other truck repairs. Some one place a barrier order already.
Old 04-12-2013, 10:24 AM
When are those 60 series barriers going to be available?
Old 04-12-2013, 10:45 AM
Is this a M101? I assume this is the task at hand.
How to lighten your wallet by $135 for 31 lbs of iron...
Old 04-12-2013, 11:45 AM
Taking the standard 2" ball off the Starcraft R/T10. I like the Lunette on my M101a. It's a 3" and works great. So I don't want to experiment with a 2.5" if I can avoid it. But for $135 I'd just add the 100 more for the max coupler.
Old 04-12-2013, 01:12 PM
I can weld something up too for about $75 in parts. Just be nice if I could find an off the self solution.
Old 04-12-2013, 04:15 PM
I hesitated to suggest welding your own draw bar because that would be a major legal and insurance headache in an accident. But yeah.
Old 04-12-2013, 04:59 PM
I welded the receiver that the pintle is on so I'm already there .
Old 04-12-2013, 09:27 PM
They are next on the list... You in for one?
