Old 04-13-2013, 12:07 PM
Default What's missing here?
Other than the wheel and tire what's missing here?Name:  ImageUploadedByTapatalk1365872827.657501.jpg
Old 04-13-2013, 12:21 PM
Lug nuts.......... and a mudflap. I'm too good, I know.
Old 04-13-2013, 12:34 PM
Yes but not what I was looking for.
Old 04-13-2013, 01:17 PM
Noise control?
KØUBN
Old 04-13-2013, 02:24 PM
LXBRADY's Avatar
LXBRADY LXBRADY is offline
Soap and water for the fender flare?
Steve Brady
TLCA # 19524
KD0JVZ
97 LX450
Old 04-13-2013, 03:22 PM
baja1d's Avatar
baja1d baja1d is offline
Tire?
Travis Hurley– Owner/ C.E.O.
Old 04-13-2013, 04:09 PM
power restrictions...
WØREK
Old 04-13-2013, 04:28 PM
Travel restrictions?
Old 04-13-2013, 04:36 PM
Noise control?
Kevin got it. EMS Powered replacement parts now installed.
Old 04-13-2013, 06:38 PM
It took all day to do. Partly due to having to remove the passenger side slider. Mine are Metal Techs. The cat skid was in the way. You may or may not have to pull Slee's but I could not tell if the front outrigger would still cause headaches.
I thought I had a pair of new O2 sensors in the garage but it turns out I only had the front. So I reinstalled the rear one. The gasket is shot and is leaking but other than that I'm really happy with the figment. Hopefully someone like NAPA has a gasket on the shelf locally.
Pic of the new inside the frame rail exit. I'll have to try extra hard to smash this on a rock.
