Old 07-01-2013, 05:18 PM
Keith's Avatar
Keith Keith is offline
Yup, I've got those.
I just saw that gamiviti is in Broomfield... So, is that you?
____________________
05 Double Cab Tacoma
64 FJ40
KEŘITH
Old 07-01-2013, 06:37 PM
Originally Posted by Keith View Post
I settled on the TM-D710 because I really wanted to be able to to cross-band repeat, would like to be able to do APRS eventually (and easily), and it gets really good reviews on eham.net.
FYI, the cross band repeat function in most radios is not legal to use in the U.S. since it does not self identify. You can use it in half duplex as a range extender on TX but you must not allow the radio to repeat the other way. The Kenwood TM-D710 and TM-V71A both support half duplex cross banding, so good choices from that perspective. The Yaesu radios also do cross band but only full duplex, so you have to mess around with odd offsets to make them half duplex. It's actually not as useful because of the half/full duplex thing. Plus even the Kenwoods don't support remote controlling channels to shut down a stuck repeater. It's very easy to get a radio into an endless loop where it continually keys itself from the repeater tail, which is why most repeater owners explicitly say not to use cross banding with their machines.
Old 07-01-2013, 07:43 PM
aye, 'tis I.
And I'd parrot most of the cross band repeat comments... it's cumbersome and really not that useful. Plus to be legit I'd need to be there at the radio, in which case I could just flip channels and relay whatever message was so important. Thoughts of hiking with the HT with a repeater in the truck quickly vanished when I realized I could likely just hit the repeater with the HT.
  #24
Old 07-01-2013, 08:54 PM
Keith's Avatar
Hmmm... So if crossband repeat isn't that useful... How useful is APRS? If everyone in the club was using it, it could be really handy... But if not... Then it's really just a novelty, right?
Going to order an antenna mount...
64 FJ40
KEŘITH
  #25
Old 07-01-2013, 10:44 PM
I've only used cross band a couple of times but use APRS all the time. But there is a lot of discussion about the utility of APRS. Certainly seems HSMM-Mesh is much more useful anymore. But hard to beat the tactical application of APRS. I know hams use it when supporting events like big cycling tours to keep track of everyone. It frees up the voice channels from constant needing to let net control know where you are, they just see who's where. It's very handy for that.
  #26
Old 07-11-2013, 08:41 AM
Originally Posted by smslavin View Post
VMWare Fusion is $50. Parallels is $60. My personal preference is VMWare.
Another option to run a virtual machine is Virtual Box. The VM is free under GNU GPL but to run Windows you'd need a copy of it.
https://www.virtualbox.org
  #27
Old 07-11-2013, 11:36 PM
This thread derailed on post 13 for the true noobs... just sayin'
  #28
Old 07-12-2013, 09:56 AM
Keith's Avatar
Well, I'm as noobie as it gets when it comes to HAM... So, let's see if I can get it back on track w/ a (hopefully) simple question... Or at least one where the answer will not involve Unix:
What size wire are you running to the radios in your trucks? I understand it's important to run pos and neg straight from the radio to the battery, but what gauge is sufficient? This question assumes a 50 watt max output power on the radio... So, 50 Watts / 12 volts = 4 amps and change, right? I'd think 12 AWG would be sufficient.
64 FJ40
KEŘITH
  #29
Old 07-12-2013, 12:09 PM
That sounds about right for mine - I think I used 10 or 12 AWG.
  #30
Old 07-12-2013, 12:32 PM
Most 50W FM mobile radios draw around 8A~9A at full transmit power. Yaesu radios (and I think most others) come with a 14AWG sized harness, usually about 9 feet (1.5 meters) long and are usually fused at either 10A or 15A. Going 12AWG would be fine for most any mobile and is a good idea generally and especially if you power run is longer than 9'.
If you're installing something larger, a 75W mobile or 100W mobile you should bump up to 12AWG if you can swing it. The FT-2900 draws about 15A at full power.
HF 100W mobiles like the FT-857 will draw 20A~22A at full 100W transmit in some modes, so use 25A fuses and at least 12AWG and 10AWG is not a bad idea.
