  #31
Old 07-13-2013, 04:06 PM
Originally Posted by Seldom Seen View Post
Dave, have you had any luck using CHiRP to reprogram your 8x7's to the new 60 meter channel?
I'm not totally familiar with the 60m allocation, but CHiRP can access the 60m channels on my radios. There is a small check box called "Special Channels" and clicking it on brings up M-601 through M-605, which are the 60m channels on my FT-817. Can you give me a hint if you mean we have a 6th channel now. I understood the last R&O increased ERP to 100W and added CW and 60Hz wide or less digital modes, it does not seem the frequency centers changed.
  #32
Old 07-13-2013, 04:30 PM
Seldom Seen's Avatar
Memory M-603 needs to change from 5.368MHz to 5.3585MHz
Instructions found here
  #33
Old 07-13-2013, 05:59 PM
Whoops, so it is. Didn't catch that change in the R&O. Just edited my file and it took fine in the 817 and 857 using regular release v0.3.1.
  #34
Old 07-13-2013, 06:26 PM
Wanna help a brother out?
