Old 04-24-2013, 01:01 PM
Kipper's Avatar
Kipper Kipper is offline
Administrator
Dang Travis, that's a bummer!
I have a complete FJ40 harness from a 2/1976 FJ40 in a box in my basement. I think it's pretty complete and I'll give you a very good deal () on it if you want to try to keep it stock.
let me know!
Old 04-24-2013, 01:09 PM
bigcity25's Avatar
bigcity25 bigcity25 is offline
I heard some type of harness call ez wire or something like that on mud was used by guys. And good thing west metro didn't come over. I wouldn't of let you forget about that....ever.
Jeff Billingsley
Denver Colo
7/70 Fj40
desmogged 2f, 4 speed
TLCA #21898
Old 04-24-2013, 01:31 PM
baja1d's Avatar
baja1d baja1d is offline
let me know!
Thank you. I think that I have one too but I figured that if I was going through the trouble I start new
Travis Hurley– Owner/ C.E.O.
Old 04-24-2013, 02:35 PM
I would look at the alternator/regulator very close. Do the wires look burned up to either one? Just a guess, it could be possible that the welding internally shorted the diodes inside the alternator.
Do the FJ harnesses not have any fuesable links in the harness? Right next to the battery?
Old 04-24-2013, 02:38 PM
baja1d's Avatar
Nearly every wire is burned including all the way up to the alternator.
Old 04-24-2013, 03:07 PM
subzali subzali is online now
FJ40s are supposed to have fusible links. They often go missing.
Old 04-24-2013, 04:30 PM
Originally Posted by baja1d View Post
I know that "painless harnesses" are pretty popular but anyone have any other recommendations?
I have a (I Think) 12 circuit Painless harness NIB I would sell for a smoking (no pun intended) great deal.
KØUBN
Old 04-24-2013, 04:32 PM
baja1d's Avatar
Text sent
Old 04-24-2013, 04:45 PM
mikeyhcrana's Avatar
I did that to a Corolla once. It was Thanksgiving time. I just welded a new roof on. We had a pot luck lunch that day, I went off and ate a huge plate, went back into a shop full of smoke. Slag rolled down inside the A pillar, melted the insulation, shorted the wires, and burned half the dash harness before I found it. I bet slag caused your short. Now I never weld anything unless I will be around the vehicle for an hour after welding.
Old 04-24-2013, 05:41 PM
PabloCruise's Avatar
Ha ha, that is funny!
Travis, I am sorry for your loss, but very happy the family and home are safe.
Have you heard of Cooler Man on Mud? He has a plethora of connectors and wiring products that might help finish the UB Painless kit.
Good luck!
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
