Old 04-20-2013, 10:17 AM
Default Can I fix this?
Top to a Weber camping grill. Cracked as seen in the pics. Are these tips made out of iron? Steel?
Old 04-20-2013, 10:23 AM
I would bet it's cast aluminum. Maybe see if you can order the part separately? Dang, did you drive over it?
Old 04-20-2013, 11:55 AM
treerootCO's Avatar
Event Coordinator
WEB92870 - Lid Assembly For Weber Q 100, Silver
View Part Info $65.99
http://www.appliancefactoryparts.com...eber/q100.html
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 04-20-2013, 11:57 AM
baja1d's Avatar
baja1d baja1d is offline
Stick a magnet on it. If it sticks, weld it!
Travis Hurley Owner/ C.E.O.
Old 04-20-2013, 01:26 PM
I know I can buy a new top, but that's 45 bones id rather spend on hookers and gin. The top is not steel, and its too light to be iron, so Martin you are probably correct. it's cracked on both ends so at this point I don't think repairing it is reasonable.
I don't really know what happened. It's been up on a shelf in the garage all winter, but this morning it was upside down on the ground. Ghosts I guess...
Old 04-21-2013, 08:43 AM
i could try to weld it for you if you want.
clean it up real well and bring it over. i have had decent luck welding cast Al in the past.
Old 04-21-2013, 09:22 PM
You could JB weld it maybe? Or drill holes and bolt on a splint. Can you tweak it back to close up the gap?
Old 04-21-2013, 10:19 PM
I thought about JB Weld too. It would be ugly, but might work. But every time I try to jimmy it and line up the crack it just seems to crack even more. It's pretty messed up... I'll probably just use it through Moab and then get a new lid before summer.
Old 04-22-2013, 09:33 AM
Drill a small hole (1/8") at the end of the crack to keep it from cracking further.
Welding it would be interesting but a Q&D fix would be to bolt a scab plate to it and get back to cooking.
Old 04-22-2013, 10:14 AM
I like the scab plate idea.
that'd be an easy at home fix and it'd look super cool all Frankenstein like.
