Go Back   Rising Sun Member Forums > For Sale + Help > For Sale / Wanted
Old 04-29-2013, 10:58 AM
girraffe girraffe is offline
Default Real time. HHEEELLLPPP!
I'm stuck in the springs. My tranny is going out on me and need to get back to aurora. If ANYONE can help please call or text. 303-526-8411
Matt
Old 04-29-2013, 11:44 AM
timmbuck2's Avatar
calling...
* 00 LC
* 99 Saab Convertible
* 76 Piggie
has a 2008 FJC
KDěTIM
Old 04-29-2013, 04:04 PM
Thanks for the call Tim. I got the truck home. Now. Does anyone want to come over and help me diagnose what's wrong with it??
Old 04-29-2013, 05:00 PM
L43dean L43dean is offline
What truck do you drive? What are the symptoms? It's good you made it home!
Old 04-29-2013, 07:11 PM
1hdt/a442f 80 series. It's the full hydraulic trams. I posted a thread up on mud too. But here is what's going on. When accelerating, the Trans studders significantly when it shifts between gears. It also starts acting like the torque converter is losing its grip after a few seconds. However I can put the truck into park and turn it off, the turn back on and accelerate slowly with no problems. After it gets up to 55-60 mph it will maintain speed for a couple minutes then "loses grip" and revs up again. Seems like decelerating causes it to "lose grip" too. When it "loses grip" all gears are affected and unable to accelerate in 1,2,3 or 4, motor just revs up. I think that's it but I'm happy to try any suggestions or investigate further questions. ANY help appreciated.
Matt
Old 04-29-2013, 07:31 PM
Crash's Avatar
Crash Crash is offline
Matt
I'm pretty sure that the A442F has an electric solenoid for torque converter lock-up. The FJ62's A440F was all hydraulic but not the A442F, if memory serves me well. You might want to check out the 3FE Yahoo list as there are quite a few 3FE 80 series guys there that know their stuff.
Old 04-29-2013, 08:03 PM
Yeah this is the jap spec hydraulic a442f. But electronics aside is there anyone in the area that could stop buy and give me a second opinion? I work from home so ill be here all day
Old 04-29-2013, 08:14 PM
So I started going through the A442f maintenance manual and noticed the the 3F torque converter stall speed is 1850 rpm and the 1H stall speed is 1900. Anyone see any adverse affects to using the 3F one if it fits?? Don't think the 1850 rpm would hurt as wholesale auto TC stall speed is something like 1700. I have a spre 3F A442trans and TC is why I'm asking.
Old 04-29-2013, 09:24 PM
rockrod rockrod is offline
Did you check the fluid level? Sometimes low fluid will cause the pump to cavitate and then you lose hydraulic pressure and the trans goes into neutral. Letting it sit for a bit allows time for the fluid to drain back, refill the pan and then you start the whole process over again when you drive for a bit.
2004 Kona Stinky dee-lux.
Old 04-29-2013, 09:32 PM
That makes sense. The fluid smells bad so ill change and report back
HTML code is On
