Old 05-15-2013, 08:29 AM
baja1d's Avatar
baja1d baja1d is offline
Default Identifying fuse-looking thing
After the welding "incident" I was forced to install an entirely new wiring harness. I'm currently working on it and came across this fuse-looking thing. Any idea what it is & do I need to in-cooperate it into the Painless? 1964 FJ40. It's on the upper passenger side of the firewall. Sorry for the lazy, non-searched, question; limited time today.
Travis Hurley– Owner/ C.E.O.
Old 05-15-2013, 08:47 AM
that should be your horn relay
Old 05-15-2013, 08:39 PM
Voltage regulator?
Zipper flange?
Old 05-15-2013, 09:23 PM
blkprj80 blkprj80 is offline
Voltage regulator probably. If someone upgraded to a newer alternator with an internal regulator, you can probably remove it entirely.
What's behind the cover if you remove it? I can't see any reason for a removable cover if it's a relay. A regulator (old school) usually has some sort of adjustment though.
- Jim
1996 FZJ80
Old 05-15-2013, 10:13 PM
baja1d's Avatar
General consensus on Mud is that it's a horn relay... Ige wins!!!
Old 05-16-2013, 07:56 AM
treerootCO's Avatar
Event Coordinator
Horn relay - I'll trade you some for it if you don't end up using it.
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 05-16-2013, 08:02 AM
baja1d's Avatar
Thanks Mike, unfortunately Steve (Poser) on Mud already dibs it.
