Old 05-29-2013, 09:53 PM
Default Picture needed - OEM fuel line routing
I need a picture of the bracket at the front of the valve cover that holds on to the OE fuel lines. Which line clips into which clip? My specific application is a 1977 FJ40 but anything in the near vicinity should be the same.
Old 05-29-2013, 10:27 PM
is this it?
Old 05-30-2013, 12:35 AM
I see both send and return lines in the bracket in the photos, and in the photos it looks like they are in the factory clip. My recollection is that the supply is on the top and the return is on the bottom. I doubt it matters which is on top or bottom.
Old 05-30-2013, 07:00 AM
Yep, thanks Tim. It's a little hard to see on my phone, but there is a clip on the side of the bracket and I'm not sure which line that is supposed to hold.
Jeff, you are probably right that it doesn't matter. I just need to do a little more pushing and pulling to get my fuel lines lined up right
Old 05-30-2013, 11:18 AM
I looked at mine and found that the return line was rubbing pretty significantly on the bypass hose for the radiator. There is a nice little divot on the hose...
So thanks for bringing this to my attention. I'm guessing mine is not set correctly, but I'm not sure why. There is plenty of "play" in that return line to move it back toward the head, but I had to zip tie it off to hold it away from the hose.
Old 06-23-2014, 12:55 AM
simps80's Avatar
simps80 simps80 is offline
Ok revival...
The bracket at front valve cover...does it mount behind lower thermostat housing on ps side bolt???
Also does anyone have a good pick of the fuel line bracket mounting for these same 2 hard lines (i think) down by fuel pump??
Thanks in advance!
Mike | KØSMP |
Old 06-23-2014, 10:36 PM
Just took a peek at my 76. It's super straightforward. Back with pics shortly
Old 06-24-2014, 10:24 AM
treerootCO's Avatar
Event Coordinator
I found the Canada Spec 2 of 76 to 4 of 79 fuel line pic
1/75 to 2/76
this pic has the one additional bracket the fuel filter bolts to
www.root45.com
www.risingsun4x4club.org
TLCA #14133
Old 06-24-2014, 10:37 AM
simps80's Avatar
yep 25 and 26 where do those mount on the engine
I am fairly certain 26 is bolted to the lower thermostat housing PS bolt, cause that lines up fairly accurately
25 though..I 'think' that must bolt through one of the side cover bolts but not sure
Mike | KØSMP |
Old 06-24-2014, 04:12 PM
26 bolts to a place that is open to the water jacket. My 40 isn't at home so I can't grab a pic
