Old 05-29-2013, 09:54 PM
Default BVSV - does it need sealant?
I am replacing the BVSV in my thermostat housing. I think it's a tapered pipe thread. Does it need sealant? The one I pulled out certainly had a bunch goobered on. Teflon tape sufficient? Don't want it to leak after I have refilled the radiator...
Old 05-30-2013, 12:30 AM
No, it does not (or at least the factory doesn't). However I use teflon tape on tapered pipe threads such as that.
Old 05-30-2013, 07:01 AM
Thanks Jeff, I was leaning towards the Teflon tape solution roo
