Old 05-30-2013, 08:13 PM
Default FJ40 Brake Booster Options?
So, my pedal has been getting squishy as I sit at a stop light. It has a really slow leak that begins to drop the pedal to the floor slowly and steadily. If I can sit there long enough the brakes start to lose grip... pump a quick half pump and they are tight again... booster right? Its been more noticeable since it has become hot.
I haven't lost a drop of fluid and during normal driving it brakes straight and quickly.
I have a mini-truck booster in there now, but I was wondering what might be my best option for performance? I am most likely going to do the rear disk swap with a proportioning valve as I have slowly collected a lot of the parts over the past few years since running the trailer.
Can I use an 80 booster? Any other good/available options? Treeroot, did you just do this conversion? Was it plug and play or was there any fab work?
Thanks!
Old 05-30-2013, 08:21 PM
I run a 3rd gen 4runner booster out of the junk yard. It is a bit larger diameter and covers one of the mounting bolts for the clutch slave - but it works great. I have disc brakes all around. I believe a booster is a booster. It is the brake master where things get to be important with regards to disc brakes and propotioning valves.
If the mini truck booster has served you well, get. A new one to replace it, install it and run it.
Old 05-30-2013, 08:46 PM
AHorseThief's Avatar
I've got an extra mini-truck booster taking up space in my garage. I pulled two when I had to replace mine so I didn't have to go back. If you want it, let me know.
Nick Kimball
'73 FJ40 Rockin a 327 SBC
Old 05-30-2013, 10:19 PM
baja1d's Avatar
baja1d baja1d is offline
I've run the Geo Metro conversion in the past with 32's, discs up front, and drums in the rear. Now the rig is SOA, has 35's, discs x4, and a proportioning valve installed but I haven't run it down the road yet. The BB is very compact & fits nicely but I'm curious about the stopping power with all the recent upgrades. Seems like Ricardo's suggestion would be the easiest, especially if it had adequate stopping power when working proficiently....
Travis Hurley– Owner/ C.E.O.
Old 05-30-2013, 11:00 PM
Bruiser's Avatar
Bruiser Bruiser is offline
treeroot used an 80 booster in his 40 and seemed to be very happy with the result.
http://www.risingsun4x4club.org/foru...t=18565&page=3
__________________________
Justin - Littleton
TLCA # 18376
KE0EJV
78 FJ40, Rear Locker, 33's, power steering, sbc and so much more left to do.
Old 05-31-2013, 08:09 AM
source3's Avatar
source3 source3 is offline
I am running disk brakes on all fours, an 80 series master, and a booster from an 82 Celica. Backing spacer is from a minitruck. I had to go with the smaller diameter booster from the Celica because of space issues on the firewall of the early '73 fj40. I had to make no adjustments to the push rod.
Andrew P.
KC5ZYF
'97 FZJ80 40th Anniversary - unlocked, 2.5" OME, sliders
Old 05-31-2013, 10:07 AM
Thanks!
You don't need a booster, you need a master that isn't leaking past the piston seal. Just because it isn't leaking to the outside world doesn't mean it isn't leaking inside. The symptom you wrote about has nothing to do with how well the booster is working, in fact it sounds like your booster is fine, but your master is leaking inside.
Old 05-31-2013, 04:33 PM
CardinalFJ60's Avatar
Default I'll agree with what Zepp said
I had this exact thing happen with my 40. I thought it was the booster...it was, in fact, the master. IMHO I'd start with that...
Old 06-01-2013, 12:34 AM
Well, that's an easy fix with new seals right? I think I rebuilt my master back in the days when I first got it.
Old 06-01-2013, 06:43 AM
If you hone the bore of the cylinder, the seals will work better and last longer.
