Old 06-02-2013, 12:03 PM
breckrider60's Avatar
breckrider60 breckrider60 is offline
Default Leaf spring front bushing help
If anyone could help me out real quick i would appreciate it. I'm replacing the leaf springs on my 4runner and i cant manage to get the front bolt that holds the spring to the frame out. I noticed on the rears which i did manage to get out there is a rubber gromet. I think this is what is holding the bolt in place. Ive tried whacking it about a hundred times with a pretty good sized hammer but it refuses to come out. I saw a video on the internet where a guy just uses a torch and burns it out. Do you think this would give me more play room to whack it out?
"When you don't know what you're doing it's best to do it quickly" - Jase #DuckDynasty
“Life begins at the end of your comfort zone.”
Old 06-02-2013, 03:59 PM
There is a sleeve inside the bushings that usually seizes to the bolt. Penetrating oil, heat, BFH and patience usually works but sometimes the torch and Sawz-All need to come out.
I'm over in Loveland and could help Monday afternoon, just today and tomorrow morning are no good.
Old 06-02-2013, 06:19 PM
Sawz-all that biatch. Cut right through the pins (bolts) and install new ones.
Old 06-02-2013, 07:41 PM
baja1d's Avatar
baja1d baja1d is offline
Yep, agree
Travis Hurley– Owner/ C.E.O.
Old 06-02-2013, 11:52 PM
I bought a crap sawza from harbor freight it wouldnt get the job done so i whipped out the grinder and that along with some kicking, twisting and knuckle busting got it out. I wish i would have just started with that i spent 3 hours trying to light the damn gromet on fire.
