Old 06-06-2013, 06:39 PM
Jenny Cruiser's Avatar
Default 1977 Fj40
I have my 40 listed on Mud and Craiglist. Hoping to find someone local to give it a new home.
http://denver.craigslist.org/cto/3839434135.html
"If you compromise the process you're an a$$hole when you start out and you're an a$$hole when you get back."
"If you don't go when you want to go, when you do go, you'll find you've gone."
"We shall meet in a place where there is no darkness."
Old 06-06-2013, 07:02 PM
MDH33 MDH33 is online now
Nice 40! Sorry you're selling. Not being able to pass smog easily will make it a little tougher to sell in Denver, but it sure has a lot of other great selling points. Good Luck with the sale!
Old 06-06-2013, 07:51 PM
TheHoneyBadger's Avatar
AH! I'd love that....
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 06-07-2013, 08:42 PM
I've been told it's possible to pass with little more than an air rail and smog pump that's hooked up. Taking the top off tomorrow. Gotta figure out how where to mount the seat belts...
Old 06-07-2013, 09:56 PM
nattybumppo's Avatar
The set belt gizmo that the belt spools in usually mounts to a roll bar base mount bolt, and the top pivot usually mounts to the roll bar junction about behind the driver's head where the horizontal rear extention meets the main vertical bar. Clear as mud?
Sascha Steinway TLCA # 20217
2013 F-150 "Black Ops"
Old 06-07-2013, 10:13 PM
That's what I did. Just looks goofy mounted down there, especially on the passenger side since the gas shroud kinda gets in the way.
Good news is I pulled the top up looking for rust and found nothing!
Old 06-10-2013, 06:04 PM
When I took the top off my '76 I remounted the seat belt retractors on the bottom part of the b-pillers instead of the normal location on the hard top part of the b-pillars.
Old 06-11-2013, 02:06 PM
I'll give that a try as the driver seat belt doesn't want to extend at all unless it is facing up like it was on the top.
Old 06-11-2013, 04:30 PM
If you use an L bracket, it mounts quite nicely to the roll bar mount, is upright, and wont crowd the filler bracketry.
Old 06-12-2013, 03:08 PM
PabloCruise's Avatar
This:
"H55F 5 spd with split case and unobtainium drum parking brake set up (works great)"
TJS K0TNP
1978 FJ-40
1974 FJ-55 w/ 3FE
TLCA #10713
HTML code is On
