Old 06-07-2013, 12:12 PM
Default Tubeless vs. normal tubes
What's the consensus on running a tubeless system on a moto? And by tubeless that really means a skinny tube that doesn't really get bigger when it inflates, just holds the bead really well. I removed my front tire and realized I had a tubeless deal, maybe that's why it was so tough to remove? So now I'm wondering if I should keep it and stick the new tire on there, or should I remove it and put a normal tube in.
Old 06-07-2013, 12:53 PM
Curious about this as well. I can see the point on a mtb, on a moto I'm a little confused...
Old 06-07-2013, 01:57 PM
baja1d's Avatar
baja1d baja1d is offline
I absolutely love mine. The "Moose Run" was my first experience with it. Normally, I would have expected to change at least one of my tires but Didn't have too....at least on my bike. Ran the whole weekend @ 10psi in the rear. I do have one complaint & that's because I never added the balance beads. The fire road to & from the trial system sucked. Gotta them now but still haven't installed
Travis Hurley– Owner/ C.E.O.
Old 06-09-2013, 07:42 AM
I run the Tubliss system front and rear. It has worked great and I have about a 1000 miles on it. I'd leave it in there.
Old 06-10-2013, 08:13 AM
Yeah I left it on there, got the new tire on the front. Here's what it looks like- when there's 100 psi in the red tube its shape doesn't really change much, but I guess its purpose is just to maintain a super tight bead...
Old 06-11-2013, 08:56 AM
I'm an regular tube kind of guy. I just dont see what you gain by being "tubeless" I haven't looked at the weight comparison, but I imagine the weight of that 100psi tube and tire sealant is higher than a regular tube.
I've bent enough rims on my moto running 17psi in tires, so I can't see running a lower pressure.
There has been some issue with the 100psi tube being damaged by heat and rim rim strips.
If the bike came with it, I'd run it, but I wouldn't go out and spend the $$
Old 06-11-2013, 12:46 PM
baja1d's Avatar
My switch was prompted by a trials tire in the rear. Heavy duty tubes just were not holding up. At $20/ tube I figured it'd add up quick. Still running regular tube up front but that has rarely caused a trail side tube change
Old 06-12-2013, 05:46 PM
Caribou Sandstorm's Avatar
Tubeless rocks
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 06-12-2013, 06:21 PM
Originally Posted by Caribou Sandstorm View Post
Tubeless rocks
On a moto?
Old 06-13-2013, 05:53 AM
baja1d's Avatar
On a moto?
Yep, I'd run tubeless with a knobby, just a little higher psi than the trials.
