Old 10-26-2014, 03:06 PM
chillbill's Avatar
chillbill chillbill is offline
Default CV Axle replacement
I need new cv axles for my 1999 4runner. Is there a place in town that sells reman toyota cv axles? If not, what are some alternatives besides new cv's from the dealer?
Bill
1999 Toyota 4Runner 5 spd., ELocker OME Lift, 215K miles, Dents and Scratches.
Old 10-26-2014, 04:33 PM
MountainGoat's Avatar
Club Treasurer
I got some rebuilt birfields for my 80 series about 3 1/2 years ago from CVJ Axles, Inc.. They have served me well. Probably worth a try.
They specifically list 4Runners on their home page.
Dan Kucera
TLCA# 17536
KDWJO
95 FZJ80 LC Red
99 UZJ100 LC Black
Old 10-26-2014, 05:10 PM
chillbill's Avatar
Thanks Dan, I will give them a call tomorrow.
Bill
Old 10-26-2014, 05:49 PM
Fishy's Avatar
Fishy Fishy is offline
For at least the 100 Series, reman cv's do not last at all and everyone ends up just buying OEM in the long run. YMMV.
Stan
UZJ100 (Non-White Edition)
OutdoorX4 Magazine Staff
100s in the Hills Co-Director
Old 10-26-2014, 06:32 PM
JadeRunner's Avatar
Cruise Moab Co-Chairman
Toyota reman axles from the dealer are typically the way to go in terms of quality. If they still sell them. I have seen things like my steering rack only available as new lately even though a year before Derek was able to get me a reman rack for much less. In which case CVJ has a nice reman rack. So yes they may be a great option for you for an axle.
Scott Yoder KD0DHP
Old 10-26-2014, 06:55 PM
DanS's Avatar
DanS DanS is offline
The last two CV axles I have replaced (a friend's '91 4-Runner, and my brother's 96 T100) we got them from CVJ. Interestingly enough, that's what Stevinson West had for one of them (CVJ remans).
Even Toyoa-purist Dan would buy them from CVJ again.
Dan
Old 10-26-2014, 07:00 PM
Romer's Avatar
Romer Romer is offline
how bad is the axle? If the boot is just ripped, you can get a rebuild kit for pretty cheap from Toyota
Ken Romer - K0ROM
14 URJ200
77 FJ40
16 RX450
16 Kimberley Karavan
Old 10-27-2014, 11:03 AM
AxleIke's Avatar
AxleIke AxleIke is offline
When you replace the axles, be sure to buy new seals. I highly recommend getting two seals for the passenger side, and installing BOTH.
This is much easier to do than setting the seal at exactly 7 mm depth, AND, with a Reman axle, you are probably 50/50 with having leak at the seal on the passenger side.
Doesn't matter where it is from, they do not weld and re-machine the stub that goes into the diff, and the seals actually wear the axle down. Because every truck is slightly different, your reman'd will have a good chance of having more wear than your seals can tolerate.
I had one NAPA brand, and TWO OEM from toyota do the same. LOTS of gear lube down the underside of the truck that took 4 or 5 car washes to finally clean off.
Looked around online, found out this was a very common problem, and this was the solution. Working great so far, zero leaks.
Isaac
Generation Dead
