Old 06-17-2013, 07:09 PM
Old40Dog's Avatar
Old40Dog Old40Dog is offline
Default Wanted 22RE
Need to find a decent used 22RE or a builder engine for my daughter Rachel's '92 mini truck.
She threw a connecting rod Sunday afternoon returning from running the Spring Creek Annual Father's Day Run with me. Bad ending to an otherwise great fun day.
Anybody have a line on one?
Old 06-17-2013, 11:06 PM
Sleepy Sleepy is offline
Jesse at ATLR has 22re's that are brand new. He can install, or will sell outright. It might be worth a look. I had one put in my son's 4runner a while back - runs great!
Barry KD0VYN
92 Toy X-cab truck Mildly modified
SAS, Dual Marlin t-cases, front & rear electric lockers
Needs a flat bed
Old 06-18-2013, 06:35 AM
mikeyhcrana's Avatar
I have one right now I'm selling. I'm parting out my 89 4runner. You can still hear it run or drive it if you want. It has a rod knock it sounds like. $100, you can have the whole motor minus wiring.
Old 06-18-2013, 03:03 PM
You have a W56 Tranny in that 4runner you want to sell?
C.J. Bowen
2015 Jeep Rubicon Hard Rock, 2000 Jeep Grand Cherokee
Old 06-18-2013, 03:14 PM
Yes, I have a w56 for sale in it. How much do you want, just the gearbox? I was thinking about keeping it all as a 5 speed conversion but, I could do it separate too.
I got a parting out thread for it too. I don't want to hijack this quest for a good 22re thread, sorry 'bout that.
Old 06-19-2013, 05:30 PM
Bump for the thread, I would try Jesse like someone suggested at ATLR....
C.J. Bowen
Old 06-23-2013, 10:47 AM
ajax ajax is offline
Have 22rte turbo and r151 tranny came out of 86 runs good shape rebuilt head good compression brother also rebuilt turbo before he pulled have engine tranny tcase and wiring, biggest issue engine is in Kansas till I get back there to bring it back
Old 07-10-2013, 07:31 AM
MountainGoat's Avatar
Club Treasurer
I don't know if you found a motor yet Dave, but here's a dirt cheap 2.7 with only 44k on it. The price would almost make it worth the extra work to swap.
Dan Kucera
TLCA# 17536
KDWJO
95 FZJ80 LC Red
99 UZJ100 LC Black
Old 07-10-2013, 04:14 PM
Old40Dog's Avatar
Any idea how much extra work?
Old 07-10-2013, 06:04 PM
Club Treasurer
Apparently there is a boatload of data on the web. I did a quick google and found this thread on the Marlin Crawler forum right off:
"From the "Drivetrain Swap Question" Thread:
The 2.7l 3RZ Engine swap is much much much easier than many fear.
In fact, your friend can use his existing stock W56 and transfercase, as it is a direct bolt on to the 3RZ's W59 bellhousing.
As for wiring, about 75% of the wires are self contained in the Engine > ECU harness, so all that is left to wire in would be the idiot gauges, ignition, alternator, starter, battery, and possibly rewire your headlights and blinkers.
As for the exhaust, I just routed mine down and below my bellhousing and placed my OBD-II cat right in the stock location as my factory cat, so everything up to the cat is compatible so he doesn't even have to change his exhaust system if he doesnt want to.
The factory 2-core radiator should be sufficient, but I would recommend using a 3-core rad. from either a 86-87' Turbo 22R-TE p/u or from a 3.0 3VZ 88-95 p/u.
If you have never done an engine swap that requires wiring before, then expect to take about a month to get it finished.
New engine mounts must be created. I cut my stock mounts off my frame and made new ones, and with a 1985 Swap that I am working on, we just modified the Tacoma engine mounts to fit right in the stock frame mounts, so no cutting on the frame was required.
Crossmember: For all 84+ rigs, stock crossmember works in the stock location. For 79-83 trucks, the crossmember will need to be moved reward as the newer style transmissions (g- or W-series) are a bit longer (~4" than the old school trans (L-series)."
Sure would be nice performance improvement for Rachel ...
Dan Kucera
TLCA# 17536
KDWJO
95 FZJ80 LC Red
99 UZJ100 LC Black
HTML code is On
