Old 07-02-2013, 09:12 PM
TheHoneyBadger's Avatar
Default Tire wear issue
So my front tires are angled out at the bottom, causing my tires to wear more on the inside of the tire.
Could this be due to old/saggy coil springs?
Travis R.
TLCA #22468
I would rather walk than drive anything that's 2WD.
Old 07-02-2013, 09:55 PM
This is more of a cause of incorrect suspension angles. When was your last alignment?
Old 07-02-2013, 10:04 PM
Right after I had my 4" lift installed. But this was happening before I lifted it. I was hoping that might line everything up. I guess not.
Travis R.
TLCA #22468
Old 07-02-2013, 10:37 PM
That doesn't sound right at all. Your alignment guy might be faulty. That Tacoma should have 0 camber if not a little positive camber. Toe should be slightly in also, giving even more of a positive camber appearance.
Worn suspension bushings could cause the angles you have, but should have been caught during an alignment.
Old 07-02-2013, 11:00 PM
Ugh...I guess maybe I should go have it checked again...
Travis R.
TLCA #22468
Old 07-02-2013, 11:38 PM
pretty sure Slee in Golden has an alignment rack now... in case you need a referral. Japanese Auto in wheat ridge is also very good with lifted toyota ifs
