Old 07-23-2013, 10:26 AM
Default Lead and Oakum Pipe Joints
While crawling under our house last night I noticed that the sewer is leaking into our crawl space.
It is leaking where the main 3" copper pipe runs into the hub of a cast iron pipe that goes under the foundation to the yard in front. It started leaking because when somebody cut a section of the 3" copper out to install a drain for the washing machine they destroyed the joint from moving it around so much.
After searching some I noticed that there are rubber donuts that can be used to seal the joint, but I also noticed that maybe doing another Lead and Oakum joint would be a better idea since it seems like t'd be more permanent to me.
Are there any plumbers in the audience that can give advice? I was going to call around and get some oakum, shove it in there with some home made caulking tools, then either pour lead in behind it or hammer in some lead wool. Any chance anybody has the tools I can borrow? Am I wasting my time and should I just try to find or make the right sized rubber donut? I just don't see that working very well.
Old 07-23-2013, 10:57 AM
Plumber, if you need one.
Kelly Hummel
303 954 8447
Tell them Dean from Meadow Hills condos sent you.
Old 07-23-2013, 12:08 PM
Fernco makes the rubber bushings. They are code approved so I imagine you should be able to get at least 40 years our of one. When I remodeled my basement bathroom, I modified a joint that I did 20 years ago with a Fernco. It was still still sealing the joint and as flexible as when it went in.
Old 07-23-2013, 12:51 PM
Dave, thanks for the plumber info, that rocks.
Bruce, Where'd you find the Fernco donut?
Old 07-23-2013, 01:12 PM
I got it at a plumbing supply shop that is no longer around. I think McGuckin's carries some of their parts. Amazon has them online. Grainger has them if you have a way to buy from them.
Old 07-23-2013, 04:28 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
George T. Sanders carries stuff like that. Pretty much anything you might need. There are locations across Denver, look em up.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 07-23-2013, 04:37 PM
kurtnkegger's Avatar
Grainger started selling to John Q. Public...You don't need a commercial connection any more.
Old 07-24-2013, 11:03 PM
Caribou Sandstorm's Avatar
I was thinking the same thing. They have a location in Denver near the Bronco's stadium, if it is still in the same location.
Chris
2001 UZJ100 Mel's rig now!
2016 Tacoma TRD OR DBCSB
TLCA# 18518
KD0IFE
FJSummit.org
Off Road Pics
Old 07-25-2013, 09:25 AM
yeah we have one up in Boulder too.
The joint is not a consistent one to allow a donut to be used very effectively, but I think I am going to give it a shot... Or call Dean/Dave's plumber.
Old 07-29-2013, 11:09 PM
OilHammer's Avatar
Post a photo. I'm not following. I have "loads" of plumbing experience....lol...
I've never seen copper in a residence other than supply. Lead, yes, copper, no. I have lead galore in my house. Lead traps, lead leaders, lead lead lead.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
