Old 08-08-2013, 03:39 PM
rckhound's Avatar
rckhound rckhound is offline
Default Looking for 14' Raft Frame
Does anyone have a Raft frame forsale? I have a 14' Vanguard and am looking for a raft frame with 4 bays preferably but I would still be interested if it has less. Let me know! Steve-looking for a frame by this weekend for a trip.
Old 08-08-2013, 04:00 PM
coax's Avatar
coax coax is offline
I don't have a frame for sale, but if you end up wanting to build yourself one, I can post up some of teh research I did. You can do a completely bolt-up frame out of Anodized aluminum for not a whole lot of money.
have a good trip!
-Corey
'74 project pig (sold)
Old 08-08-2013, 04:17 PM
rckhound's Avatar
Would Love to see it.
Old 08-08-2013, 04:40 PM
gr8fulabe's Avatar
Me too! That sounds like just the ticket for a budget upgrade from my current frame.
I've got a frame I would lend you. Bu not for this weekend unfortunately...
Old 08-26-2013, 09:35 AM
coax's Avatar
Ok, sorry for the delay, but here's what I was able to come up with when I was planning to build a double rail raft frame. As a disclaimer, I never got around to building it because the deal on the rubber fell through.
Tube: NRS sells anodized pipe by the foot. While not cheap, it was much cheaper than other on line metal places i found, its the correct size, and its already anodized.
http://www.nrs.com/product/1211.2/nr...-1-58-anodized
Fittings: Unless you want to try your hand at tig welding anodized aluminum, you can buy all the fittings necessary to build up a frame. I believe the 1-1/4" pipe has an OD of 1-5/8, so those are the fittings to get. They come in T's, elbows, crosses, etc.
http://www.nurail.com/products/%2310...B47%7D4in.html
Towers: You can get these from DRE, with the modified tower to fit the 1-1/4" pipe on the frame to the 1-1/2" oar tower.
http://downriverequip.com/index.php/...oar-tower.html
http://downriverequip.com/index.php/...ers-bases.html
From there, its just designing it how you want it. Not cheap, but you can make it the way you want, with an umbrella holder, cross bars for coolers, etc.
HTH!
-Corey
HTML code is On
