  #41
Old 09-03-2013, 02:50 PM
So I replaced the rad cap with the appropriate 7psi working unit (specified in O'Reilly's book for a 1955 Chrysler or DeSoto whatever... ). Works great. Now the cooling system develops pressure.
Until the pinhole in the radiator seam leaks it out, along with the water pump seal...
Good thing this stuff is available fairly cheap... found a shop who actually remembers how to solder together a radiator. Better than throwing a Chinese 'sorta' reproduction radiator in it.
Changed the oil... it NEEDED it. Found out the oil filter access cover in the oil pan was welded shut, as many were (inasmuch as they were very difficult to seal). Sigh. Not a big deal to pull the oil pan, but not having planned on it, I had no gasket. Oh well, it needed some 'cleanout' oil run through it for a while anyway.
I keep thinking about that pretty little fully restored Fergie that came on the market AFTER I bought this one. For more than twice as much, but... ah well, I got a lot more work to do before I burn through THAT much difference.
KDěRCH
