Old 08-24-2006, 02:06 PM
Default front output seal
Is the front output seal on the t-case easy to replace? Mine's getting worse and I'm sick of topping off the t-case, thought my problem was the rear output seal but apparently that wasn't the only one...go figure
Rising Sun Bio
Old 08-24-2006, 02:16 PM
yes and it's the same part # as a pinion seal
