Old 09-15-2013, 07:44 PM
Default Flooded Crawl SPace
The creek overflowed behind our house and poured into the crawl space. Our crawl Space is now a swamp. I got standing water out but it is nasty still since the soil is saturated..
Do I let it dry with fans and wait or do I have a bigger problem?
It is just a dirt bottom, no vapor barrier or anything with minimal venting to the outside.
Old 09-15-2013, 09:03 PM
baja1d's Avatar
baja1d baja1d is offline
Lots of fans. Open all windows when you can to let moister out. If you have a/c, I'd run it when the windows are closed. Normally you can rent de-humidifiers but I'm guessing everyone available has been rented. Remove anything that maybe saturated with water- i.e. carpet, drywall. I've got a carpet fan you can borrow if you'd like. The biggest thing is to get air exchanging ASAP.
Travis Hurley Owner/ C.E.O.
Old 09-15-2013, 09:05 PM
OilHammer's Avatar
Do you have an in and and out? If so, pressurize it with a fan and keep the air moving. This coming week should be a much lower humiditiy. If you can find one, look for an old belt drive HVAC blower squirrel cage type unit. They move a TON of air. Kind of like this one: http://boulder.craigslist.org/for/3973574265.html
Mine looks kind of like this one http://fortcollins.craigslist.org/for/4063709661.html
You are welcome to borrow mine, but I will need to unistall it from the attic. Usually you can find them cheap, and they're so darn handy, I recommend having one for your garage for the summer anyway.
Here's a direct drive one cheap http://denver.craigslist.org/for/3980152641.html
If you have a motor http://denver.craigslist.org/gms/4026756279.html
Centrifugal fans work very well too. All the pot houses sell them. I put a HUGE one over my cooktop.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 09-15-2013, 11:00 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Ventilate. Any equipment in there?
Old 09-15-2013, 11:36 PM
no equipment in there, it's just pipes and stuff.
Cool, sounds like just let it dry with lots of fans type of thing I can do that.
Old 09-16-2013, 09:49 AM
FJCDan FJCDan is offline
Hi Marco, just do what Travis recomended get air movement going. This will take awhile since the ground is totally saturated now. I was in Boulder yesterday and water was coming everywhere I mean everywhere, bubbling up through cracks, foundation walls and anywhere water could come through. Every basement I did in Aurora on Friday and Saturday all flooded again so I get to start all over again. Good luck we all need it right now.
