Old 02-06-2018, 03:44 PM
white wings's Avatar
white wings white wings is offline
Default Anyone tried this wicked cheap light controller?
I found it at AutoZone and it seems to do the job of light relay and controller without the need to pass through the fire wall.
Unlike the 80 and 100, I found limited space in the GX for switches without drilling 3/4" holes all over the dash.
I should be able to handle the swap out from poorly routed switches to this system tomorrow. I'm running 2 10" light bar spots, 2 rigid amber spots, 2 rigid ditch light floods which seems to be well within the limits of this unit.
$39.99 was the cheapest I found it and it's available at autozone now for store pick up.
http://www.blazer-international.com/...=C3050K&cat=16
Driving my wife crazy with no garage parking since 2006
Old 02-06-2018, 04:37 PM
Just got this home and it's a aluminum body, sturdy unit. She'll sit nicely on the Slee air comp tray.
Old 02-06-2018, 08:03 PM
baja1d's Avatar
baja1d baja1d is offline
Can’t beat the price
Travis Hurley- Founder/Owner
Outer Limit Supply | 720-987-4202
www.outerlimitsupply.com
Travis Hurley– Owner/ C.E.O.
Old 02-06-2018, 08:47 PM
gahi's Avatar
gahi gahi is offline
wow, that's cheap for what it is. the keypad is the buttons in the pic?
Gary
1996 FZJ80
2000 UZJ100
Old 02-06-2018, 10:55 PM
74fj40's Avatar
74fj40 74fj40 is online now
I say go for it!
2005 Silverado 2500hd Duramax
1972 Toyota FJ40
1967 Porsche 912(100% stock)
[/font]
Old 02-07-2018, 12:05 AM
I have it in my hand. It's the same shape and feel as a standard garage door opener with the buttons below a a weather resistant cover.
I'm mapping out what lights I want set up for each color/amperage right now. I may do a left/right of vehicle to start and perhaps pair them up if I add additional lighting.
The control box is a beer can in length and 3/4 can in width and 1/4 can tall (guess what I had close to me for a US standard measurement tool?)
both positive and negative leads are about 2.5 feet long.
Old 02-07-2018, 11:46 AM
Are you actually running all the power through the switch box or is it a relay?
How many lights will it control?
Old 02-07-2018, 03:57 PM
OilHammer's Avatar
OilHammer OilHammer is online now
Hopefully the remotes are all the same frequency and code so you can turn your friend's lights on and off each time he is about to pass a cop.
1966 FJ45 lwb stock
2003 100 OME lift
KD0PZL
Old 02-07-2018, 04:20 PM
Rezarf's Avatar
Rezarf Rezarf is offline
Report back, this is interesting to me. Saves a lot of wiring and switches. Are the relays built in? I am assuming you power the controller from the battery and then just pop on the leads of each light? That'd be pretty rad.
Rezarf <><
K0RZF
My rig... "Maude"
Old 02-07-2018, 04:23 PM
MTSN's Avatar
MTSN MTSN is offline
Reminds me a little of the Trail Toys NSA switch panel I put in my last 200 - it used a remote control with a good range including one button that turned on everything at once. https://trailtoys.net/products/nsa-switch-panel
Current: 2017 Tacoma, 2008 200 series
Former: 2014 200 series, 1998 100 series
TLCA# 22666
