Old 10-14-2013, 10:53 PM
baja1d's Avatar
baja1d baja1d is offline
Default FJ 40 Saginaw Power Steering Set up
Collected parts to put the "Ikea Build" back together but just sold the frame & tub. Therefore, I will not need these bits.
Brand new parts:
-Saginaw p/s gear box (reconditioned)
-P/S cooler
-P/S filter
-Frame Slug
-GM pitman arm nut & washer
-Low pressure return line
*All the above pieces are $185, you'll save on shipping...
For an extra $100 I'll throw in a GM tilt steering column & both of the 1/4 frame plates. You'll still need a firewall support, high psi line, steering shaft, 2-3 u-joints, pitman arm, & possibly a heim joint depending on your particular setup; ie, 2F vrs. 350. This isn't a cheap setup but well worth every dime spent. All total, it's about a $500 upgrade & involves welding. 72o-987-42o2 or send me a PM
Travis Hurley– Owner/ C.E.O.
HTML code is On
