Old 01-14-2014, 04:35 PM
Default Blinkers don't reset after turn - FJ60
So...I fixed the horn with a new pin-thingie behind the wheel. Horn works...now the blinkers don't reset after taking a turn...what did I do!? or just a coincidence? How to I fix that? not a huge deal to flip the stalk, but jeeeesh. TIA
Old 01-14-2014, 04:57 PM
baja1d's Avatar
baja1d baja1d is offline
There's usually a small stud on the wheel that flips a cam to reset the blinker switch. They sometimes fall off/out if you removed the wheel. Another option/possible problem is that the cams are sometimes spring activated. That spring may have broken or been dislodged. I've also seen them loaded up with gunk, making them inoperable.
Travis Hurley Owner/ C.E.O.
Old 01-14-2014, 05:06 PM
I think my 60 did that. The thing that hooks the pin to cancel the switch is plastic. The pin wears the corners off of the plastic over time so that the hook doesn't effectively latch onto the pin. You might be able to make a slight position adjustment to the hook thing to get it to work, or you might have to sharpen the corners of the hook with a file to get it to latch. Once you get it apart and can see it, it should make sense.
Old 01-14-2014, 05:26 PM
Default not on the wheel, right?
thanks guys, makes sense.
So...if I pull that plastic cover again, I might be able to see if that part fell off or needs some 'finessing'?
I did brush a bunch of crap out of there, maybe I lodged something in there?? I'll double check.
There's no need to pull the wheel again, is there?
Old 01-14-2014, 06:15 PM
rover67 rover67 is online now
60's have horns? I never knew..
Old 01-15-2014, 09:18 AM
Mine sure doesn't
Old 01-15-2014, 12:54 PM
jps8460's Avatar
jps8460 jps8460 is offline
Commander
My 60 started doing this as well. I ordered a tiwanees mulyifunction switch off of ebay to replace mine. I'll post up about quality of the unit when I receive it. It was $50
Old 01-15-2014, 12:55 PM
jps8460's Avatar
Commander
If it wears out I might just make something to replace the plastic part that wears out
Old 01-15-2014, 08:12 PM
Make a CAD model and I'll print it for you
Old 01-15-2014, 09:48 PM
jps8460's Avatar
Commander
Man great Idea! From what I gather this is a pretty common issue. After I get it torn apart I'll whip up a model for you. Any format you prefer? I have solidworks 2012....which can make a shell in just about any format.
