Old 10-27-2013, 10:00 PM
Default 80 series rear wiper issue
Calling electrical gurus.
Rear wiper operates on intermittent even when switch is turned off.
I checked the switch and didn't have continuity between pins 1,2,10, and 16 when switch was off.
So is it the relay or the wiper motor? Or should I check the switch again?
See attached pdf...
The relay side of the L-R wire is getting 12V when the wiper motor is disconnected. I think it's supposed to be 0? So if that's true that points to the relay.
Pins 1 and 4 of the wiper motor have continuity, about 20 ohms resistance. I think they are not supposed to have continuity at rest, so if that's true that points to the wiper motor.
Or maybe I'm reading something wrong?
Rising Sun Bio
1996 FZJ80 1FZ-FE factory lockers + Safari intercooled turbo, CDL switch, cup holder, Metric TLC leather, heated seats and JDM switches
Old 10-28-2013, 09:32 AM
Snowrun's Avatar
Snowrun Snowrun is offline
I have the same issue and it drives me nuts. It would be nice to figure out what is causing it.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
Old 10-28-2013, 10:18 AM
60wag 60wag is online now
Can you unplug the L-B connector between the switch and the relay and see if it still does intermittent?
Old 10-28-2013, 11:51 AM
I was trying to figure out the ground path for the current, I'll see if I can just undo the L-B. I don't think I can but I might be able to get creative with alligator clips.
If it still operates in intermittent then it's gotta be the relay or the motor, if it stops then I need to look at the switch again.
Rising Sun Bio
Old 10-28-2013, 02:06 PM
Just to keep the documentation in this thread, the L-B wire comes back up the harness through a connector (BR1) in the storage panel.
That connector also has:
-R-Y - Rear door courtesy light
-L-Y
-L-G - from rear wiper relay to switch for wiper ON function.
-W-B - ground for rear wiper motor and possibly other stuff (defogger, high stop light, door courtesy), so that needs to be connected.
-G-W - rear stop light
-Y
-B - rear window defogger
Have to identify what those go to and if having them unplugged will affect anything.
Might also see if BT1 would be a better place to unplug.
Wires in BT1:
-L-power to the wiper motor
-L-B-from rear wiper relay to switch
-L-G-from rear wiper relay to switch
-B/L-G-rear window defogger
-L-R-rear door lock
-L-W-rear door lock
Rising Sun Bio
Old 10-28-2013, 04:42 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Mine does not work at all and I will tackle it before winter sets in. I'll be following this thread
Daniel Markofsky - Daniel@Markofsky.com KDGWR
Old 10-28-2013, 10:02 PM
Okay, I disconnected BT1 and ran a jumper for the L wire. The wiper stopped working with the switch OFF (yay, I think I found the problem?). I switched it to ON and jumpered the L-G wires and it worked as designed.
Earlier I pulled the relay and tested it per BE-25 in the FSM. I think it tested out ok. The only thing I'm not sure of is this phrase in Step 3: "...check that the meter needle rises from 0 V to battery positive voltage within 6 to 10 seconds. If operation is not as specified, replace the relay."
The voltage rises to battery voltage almost immediately, not between 6 to 10 seconds. Think it's ok?
Going to check the switch again.
On a good note I busted out the epoxy and I think I fixed the shaky driver side mirror. So at least I'm making forward progress.
Rising Sun Bio
Old 10-29-2013, 03:06 PM
I pulled apart the dash and checked the switch plug again. It appears fine. I need to get a better continuity tester though; my digital multimeter (set on ohms) kinda bounces around but then always lands on infinite resistance.
In fact, same thing happened last night when I was checking around the BR1 connector in the rear quarter panel. Unplugged, the L-B resistance to ground would bounce around and then land on infinite. It was doing some other weird things that I should confirm and document (got a test light today to do that), but I'm worried that the problem is in the wiring somewhere. I hope not. It's all in good shape, the fasteners, wiring, connectors, etc. no corrosion just a little dusty so I'm amazed there's a problem.
Rising Sun Bio
Old 10-29-2013, 07:51 PM
Well I got a test light and the L-B isn't grounded with the switch off. So now I'm not sure what to do, feels like I have to start over.
Rising Sun Bio
Old 10-29-2013, 10:31 PM
BR1 contains:
-L-B - from rear wiper relay to switch
-L-Y - stops at connector
-Y - nothing?
BR1 forward to the switch:
-L-B - NO path to ground
-R-Y - NO path to ground
-L-Y - NO path to ground
-G - NO path to ground.
-W-B - path to ground
-G-W - path to ground
-Y - path to ground
-B - path to ground
BR1 back to hatch:
-W-B - NO path to ground
-G-W - NO path to ground
BR2 contains:
-L-W - rear door lock
-L-Y - rear defogger
-L - power to rear wiper relay and motor
-L-R - rear door lock
BR2 forward to switch:
-L-W - path to ground
-L - path to ground
-L-R - path to ground
BR2 back to hatch:
-L-W - NO path to ground
-L - NO path to ground
-L-R - NO path to ground
BT1 contains:
-B/L-G - rear window defogger
-L - power to the wiper motor
BT1 back:
-B - path to ground
-L-G - NO path to ground
BT1 forward (BR1, BR2 unplugged):
-B/L-G - NO path to ground
BT1 forward (BR1 plugged in, BR2 unplugged):
BT1 forward (BR1 unplugged, BR2 plugged in):
-L - path to ground
BT1 forward (with BR1, BR2 plugged in):
-B - path to ground
-L - path to ground
Relay terminal back to switch (BR1, BR2 unplugged):
Relay terminal back to switch (BR2 unplugged, BR1 plugged in):
Relay terminal back to switch (BR1, BR2 plugged in):
-L-B - path to ground
-L - path to ground
Rising Sun Bio
