Old 11-02-2013, 10:35 PM
The pins in the switch have infinite resistance when switch is off and 1.4 ohms when switch is in intermittent.
Old 11-04-2013, 05:32 AM
I've never dug into the wiring bundle going through the top of the hatch on the 80 but it does sound like you have eliminated the switch and the relay as the problem. I did repair a washer hose in the top of the hatch on a 60 once. That was way more work than it should have been.
