Old 11-03-2013, 08:15 AM
Default Chainsaw problems - where is good service shop?!
My Stihl Farmboss works fine (most of the time) - yesterday was a perfect example: worked fine morning 'till about 1:00pm - no issues starting, restarting.
After lunch, it wouldn't start for s&it - no matter what I tried. It sure was flooded eventually, so I took the spark plug out, let it sit 10-15mins... re-tried. Still no start - did that all afternoon, while cursing quietly and steaming...
Spark plug is new - in case you're wondering.
So, I need to have someone look at it. I'm up north (Westminster) - does anyone know of a good reputable service shop that can service this thing?!
James DePaul
Old 11-03-2013, 09:04 AM
Woodsman's Avatar
Woodsman Woodsman is offline
Air filters and gas are the biggest issues I've run into.
The ethanol in most gas eats up the hoses and gaskets in these small engines. I've started using additives which "neutralize" the alcohol and hope this works.
Did you have the on switch flipped the right way ? hehe It happens.
08 FJ Cruiser with a few mods
TLCA#19287 -Since 12/08
Old 11-03-2013, 11:15 AM
TheHoneyBadger's Avatar
Land Use Coordinator
I would definitely recomend cleaning the air filter. Maybe change the fuel filter. Definitely use a fuel additive that neutralizes that stupid ethanol crap. You can find that kind of additive at Home Depot or Lowes.
Sorry, I don't know of any good service shops around here. (haven't lived here long)
Travis R.
TLCA #22468
The "Honey Badger"- 2003 Tacoma 4x4 4-Door -Lifted, Locked, Built. Abnormally aspirated.
I would rather walk than drive anything that's 2WD. ©
Old 11-03-2013, 12:19 PM
Squishy!'s Avatar
Squishy! Squishy! is offline
Pm RedChili. There is a shop in aspen park/conifer that took REALLY good care of him. He'll recommend it to anyone that'll listen.
-Justin Morgan,
TLCA #23166
"RedChili"-1987 Super Beast
Old 11-03-2013, 01:23 PM
Yeah, I've set the switch right on Choke from cold (after lunch) and tried a few times (about 10) but it didn't "cough" like it should normally. Took out the air filter and the spark plug, let it vent, tried without air filter on it and even tried spraying starting fluid into it.
My gas had Stabil in it - but I dumped it and filled up with somone else's gas that was running his chain saw next to me... embarrassingly my Stihl refused to work after lunch.... no matter what I did... lazy cr&p.
Ok - thx for the leads.
James DePaul
Old 11-03-2013, 02:26 PM
Thumbs up
Earls Saw Shop in Boulder is top notch!
KØUBN
Colorado Trail Patrol
Stay on the Trail!
Old 11-03-2013, 03:17 PM
baja1d's Avatar
baja1d baja1d is offline
Heard good things about Arvada Rentals. Most of the local fire departments send their saws to them
Travis Hurley– Owner/ C.E.O.
Old 11-03-2013, 06:53 PM
Thx for suggestions - I tried the bloody thing again today... and wouldnj't you konw it - it fired right up on the second pull..... lazy thing didn't want to work yesterday in the cleanup - could have used it then... but today it works fine... Crappy thing. It's off to the shop anyway -
Thx
James DePaul
Old 11-03-2013, 07:18 PM
baja1d's Avatar
Sounds like a clogged pickup tube inside the tank. I've got an old Jonsered that does the same thing
Old 11-03-2013, 07:29 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Tennyson Hardware
Daniel Markofsky - Daniel@Markofsky.com KØFZJ
