Old 10-27-2013, 10:00 PM
Default 80 series rear wiper issue
Calling electrical gurus.
Rear wiper operates on intermittent even when switch is turned off.
I checked the switch and didn't have continuity between pins 1,2,10, and 16 when switch was off.
So is it the relay or the wiper motor? Or should I check the switch again?
See attached pdf...
The relay side of the L-R wire is getting 12V when the wiper motor is disconnected. I think it's supposed to be 0? So if that's true that points to the relay.
Pins 1 and 4 of the wiper motor have continuity, about 20 ohms resistance. I think they are not supposed to have continuity at rest, so if that's true that points to the wiper motor.
Or maybe I'm reading something wrong?
Old 10-28-2013, 09:32 AM
Snowrun's Avatar
Snowrun Snowrun is offline
I have the same issue and it drives me nuts. It would be nice to figure out what is causing it.
'94 FZJ-80 Locked
'99 LX 470
TLCA#21035
My Cruiser videos on Youtube
Old 10-28-2013, 10:18 AM
Can you unplug the L-B connector between the switch and the relay and see if it still does intermittent?
Old 10-28-2013, 11:51 AM
I was trying to figure out the ground path for the current, I'll see if I can just undo the L-B. I don't think I can but I might be able to get creative with alligator clips.
If it still operates in intermittent then it's gotta be the relay or the motor, if it stops then I need to look at the switch again.
Old 10-28-2013, 02:06 PM
Just to keep the documentation in this thread, the L-B wire comes back up the harness through a connector (BR1) in the storage panel.
That connector also has:
-R-Y - Rear door courtesy light
-L-Y
-L-G - from rear wiper relay to switch for wiper ON function.
-W-B - ground for rear wiper motor and possibly other stuff (defogger, high stop light, door courtesy), so that needs to be connected.
-G-W - rear stop light
-Y
-B - rear window defogger
Have to identify what those go to and if having them unplugged will affect anything.
Might also see if BT1 would be a better place to unplug.
Wires in BT1:
-L-power to the wiper motor
-L-B-from rear wiper relay to switch
-L-G-from rear wiper relay to switch
-B/L-G-rear window defogger
-L-R-rear door lock
-L-W-rear door lock
Old 10-28-2013, 04:42 PM
Inukshuk's Avatar
Inukshuk Inukshuk is offline
Mine does not work at all and I will tackle it before winter sets in. I'll be following this thread
Old 10-28-2013, 10:02 PM
Okay, I disconnected BT1 and ran a jumper for the L wire. The wiper stopped working with the switch OFF (yay, I think I found the problem?). I switched it to ON and jumpered the L-G wires and it worked as designed.
Earlier I pulled the relay and tested it per BE-25 in the FSM. I think it tested out ok. The only thing I'm not sure of is this phrase in Step 3: "...check that the meter needle rises from 0 V to battery positive voltage within 6 to 10 seconds. If operation is not as specified, replace the relay."
The voltage rises to battery voltage almost immediately, not between 6 to 10 seconds. Think it's ok?
Going to check the switch again.
On a good note I busted out the epoxy and I think I fixed the shaky driver side mirror. So at least I'm making forward progress.
Old 10-29-2013, 03:06 PM
I pulled apart the dash and checked the switch plug again. It appears fine. I need to get a better continuity tester though; my digital multimeter (set on ohms) kinda bounces around but then always lands on infinite resistance.
In fact, same thing happened last night when I was checking around the BR1 connector in the rear quarter panel. Unplugged, the L-B resistance to ground would bounce around and then land on infinite. It was doing some other weird things that I should confirm and document (got a test light today to do that), but I'm worried that the problem is in the wiring somewhere. I hope not. It's all in good shape, the fasteners, wiring, connectors, etc. no corrosion just a little dusty so I'm amazed there's a problem.
Old 10-29-2013, 07:51 PM
Well I got a test light and the L-B isn't grounded with the switch off. So now I'm not sure what to do, feels like I have to start over.
Old 10-29-2013, 10:31 PM
BR1 contains:
-L-B - from rear wiper relay to switch
-L-Y - stops at connector
-Y - nothing?
BR1 forward to the switch:
-L-B - NO path to ground
-R-Y - NO path to ground
-L-Y - NO path to ground
-G - NO path to ground.
-W-B - path to ground
-G-W - path to ground
-Y - path to ground
-B - path to ground
BR1 back to hatch:
-W-B - NO path to ground
-G-W - NO path to ground
BR2 contains:
-L-W - rear door lock
-L-Y - rear defogger
-L - power to rear wiper relay and motor
-L-R - rear door lock
BR2 forward to switch:
-L-W - path to ground
-L - path to ground
-L-R - path to ground
BR2 back to hatch:
-L-W - NO path to ground
-L - NO path to ground
-L-R - NO path to ground
BT1 contains:
-B/L-G - rear window defogger
-L - power to the wiper motor
BT1 back:
-B - path to ground
-L-G - NO path to ground
BT1 forward (BR1, BR2 unplugged):
-B/L-G - NO path to ground
BT1 forward (BR1 plugged in, BR2 unplugged):
BT1 forward (BR1 unplugged, BR2 plugged in):
-L - path to ground
BT1 forward (with BR1, BR2 plugged in):
-B - path to ground
-L - path to ground
Relay terminal back to switch (BR1, BR2 unplugged):
Relay terminal back to switch (BR2 unplugged, BR1 plugged in):
Relay terminal back to switch (BR1, BR2 plugged in):
-L-B - path to ground
-L - path to ground
